Originally Posted by
babkalakal
halos lahat naman ng obd2 scanner will easily read honda and mitsubishi isuzu protocols. cheap generic ones will do fine even the blue tooth based dongles will work. Branded ones autel, inova, actron if you like some can reset abs srs too but they are not cheap especially if you are not using them on a regular basis. kun DIY lang you do not have to spend that much. personally hinahanap ko yun nag babasa din ng toyota IMV vehicles. Aside from professional grade obd scanners ( read: super expensive) wala pa ako mahanap nag babasa ng toyota IMV(diesel innova hilux fortuner hiace) . mga sedan cuv gas suv nila no problem basahin. I've borrowed a midrange autel maxi diag elite di din mabasa toyota imv.
