Results 21 to 30 of 210
May 12th, 2011 09:52 AM #21
sir is this thesame as the link below?
http://www.racechip.de/index.php?language=en
if parehas me chance pa kaya bumaba price nito sir like advertised sa site ng racechip for 130euros and racechip PRO for 230eu? also meron naba kayo available for Montero GLS-V or 2.5 diesel 178hp vgt model?
thanks
- Apr 2011
- 1
May 12th, 2011 12:37 PM #22
May 12th, 2011 06:10 PM #24
May 13th, 2011 04:27 PM #25
Hi don,
Yes this is the German site. We are the official reseller here in the Phils. We only sell the Racechip Pro kits, as these have the most gain and are the easiest to use. Your car is compatible. I asked especially about VGT engines in germany and they told me that is not a problem since they have been using vgt's for a long time there. The other costs of importing it, that we already paid are the shipping costs (the one listed on the site is germany only), then the taxes and duties and the installation that we will be doing.
May 13th, 2011 04:31 PM #26
Hi Olidotcom,
There is a version for gas engines, but the cost is more than double, it is still very new so the compatible cars that have been tested are low and as per Germany you need to have a turbocharged engine. For all these reasons we are holding off on bringing them to the Philippines for now (special request only). we have not yet tested this version either, unlike the diesel Chip.
- Nov 2009
- 15
May 14th, 2011 12:21 PM #27hi sirs. I drive a 2010 a/t ford focus tdci 2.0. is the chip compatible? and won't it void the electronics warranty of the car talaga?
tia
BANNED BANNED BANNED
- Mar 2011
- 479
May 15th, 2011 02:27 AM #28Sounds very good sir!
With an indicative (not dynoed) 30% more power and 20% more torque gains, how does it compare with Berrima Diesel's DPChip and Speedlab's Unichip, say on 3-litre diesel CRDi engines? i'm actually looking into the PhP30k Unichip installation (includes also chassis dyno tuning) very soon, but will consider the RaceChip if the gains are better than the other two mentioned.
Thanks for any feedback sir....
- Feb 2011
- 145
May 15th, 2011 07:11 PM #29Hi sir,
I want to inquire if this product is compatible to my Nissan Patrol having a ZD30 engine. currently my maximum speed is 160kph. when im running 160 my rpm is 3300rpm, and when I step on the gas the rpm continues to climb but my speed remains 160kph. Is this due to a speed limiter? if so can this product disable my speed limiter too? TIA
May 15th, 2011 07:24 PM #30
With regards to speed limiters, this is usually controlled by the vehicle's ecu. There are devices that can be installed to either delay or totally defeat the speed limiter of many vehicles.
You would probably need to refer to more specialist car/engine tuner shops for this kind of help for your vehicle.
high idle RPM at engine start
