Quote Originally Posted by speed unlimited View Post
Okay naman bosch platinum pag toyota kasi NGK kadalasan gamit ko . Toyota 12R makina mo . Okay lang naman na nakakabit ang breather hose sa air filter case iyon kasi ang stock na pinaglalagyan nito.
Thank you po. Ibabalik ko un hose sa may kabitan ng air filter, pansin ko lang kasi pag medyo matagal tagal nang nakakabit parang may oil residue sa may lalagyan ng air filter
Quote Originally Posted by CivicVTi View Post
Kung same specs sya sa original (gap clearance, etc) ok lang. Pero kung hindi ka sure, ibalik mo na lang yung stock plugs.
Better if you use gasoline na wala pang halong ethanol like Petron Blaze (for the meantime, next year Blaze will also be mixed with E10 as mandated by law). Since its an old car with an old engine, better have a trusted carb mechanic check and if possible "upgrade" it so it will resist the ethanol content. Some rubber parts of the fuel line from the gas tank to the engine may also require replacement.
thanks for the info, ill start using blaze from now on, better safe than sorry
