Hi tsikoteers, my car has oil leaks on the bottom and side of the engine, bale back job ng general overhaul that was recently done, magtatanong lang ako sa mga nakakaalam kung gaano po ba katagal para palitan mga gaskets kasama na un pagbaba ng makina, sabi sa akin ng mekaniko na gagawa ay mga 2 days para magawa niya iyon, ganon po ba talaga katagal?Natatakot kasi ako iwanan uli sa shop na iyon ang car ko kasi last time na nandon car ko nawala un mga chrome covers ng tires (un takip sa lalagyan ng hangin) and un 2 bagong floormats(carpet) ko napalitan ng luma... how long po ba talaga para ibaba ang engine at palitan ang mga parts na nagle leak ng oil? thanks po!
. the engine just went through a "general overhaul", all it needs is resealing because the shop that dit it messed up a simple job. what is your model year, make and model of the car, what is the engine? there are two standards as to how long a particular job takes to do. there is the factory time guide and there is industry aftermarket time guide. the difference is the factory time is shorter that they have averaged the time it took them after at least three attempts and that the components are clean and the bolts, fasteners are new and not rusted. these are the usual source of leaks: front main seal, camshaft seal, oil pump seal(where applicable), rear main seal, valve cover gasket, oil pan gasket and the PCV system. there are generally two kinds of leaks: pressure leak and seepage, gravitational and capillary leaks.
