Results 1 to 7 of 7
November 20th, 2010 05:59 AM #1
Hi mga fellow tsikoters..
Quick question, how can i bleed or replace my power steering fluids?
san po pwede siya e drain?
help po..
Honda Civic 2000 M/T.
TIA
November 21st, 2010 06:17 PM #2
disconnect the return hose, paandarin while nilalagyan mo reservoir (wag hayaan maubusan laman ang reservoir).
THE AUTO SPECIALIST
- Mar 2006
- 607
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 17th, 2010 08:00 AM #5actually for power steering it's not too bad for air to get into the system since it bleeds itself off automatically when the pump is turning. just refill and let it run. once there are no more bubbles from the ps reservoir it should be ok na.
December 17th, 2010 08:43 AM #6
i believe i also asked in relation to my power steering fluid din.. pass on ko lang dito...
to ensure that all fluids are removed, you need to turn your steering wheel from end to end to have all pumped out.
- Nov 2003
- 3,849
December 18th, 2010 06:57 AM #7ok lang naman to not move the steering wheel na. in most cases the ps pump will get all old fluid out even without moving the wheel
Parang maintenance ng Master Garage ito? Sent from my 2107113SG using Tsikot Forums mobile app
