Results 1 to 7 of 7
    Aug 2006
    Hi mga fellow tsikoters..
    Quick question, how can i bleed or replace my power steering fluids?
    san po pwede siya e drain?
    help po..
    Honda Civic 2000 M/T.
    TIA
    disconnect the return hose, paandarin while nilalagyan mo reservoir (wag hayaan maubusan laman ang reservoir).
    ^^^ thats the way.
    Aug 2005
    air getting into the system is very bad. ingat lang sa pag bleed.
    Nov 2003
    actually for power steering it's not too bad for air to get into the system since it bleeds itself off automatically when the pump is turning. just refill and let it run. once there are no more bubbles from the ps reservoir it should be ok na.
    Apr 2010
    i believe i also asked in relation to my power steering fluid din.. pass on ko lang dito...
    to ensure that all fluids are removed, you need to turn your steering wheel from end to end to have all pumped out.
    Nov 2003
    ok lang naman to not move the steering wheel na. in most cases the ps pump will get all old fluid out even without moving the wheel
Power steering fluids
