Results 1 to 10 of 21
June 12th, 2003 06:42 PM #1
Aside from oil and fuel filters, ano pa ba ang dapat pinapalitan sa diesel vehicle to maintain good running condition? Crosswind XTO po ang ride ko, 35K km na odo rdg. Thanks. :roll:
- Nov 2002
- 51
- Nov 2002
- 51
June 12th, 2003 11:03 PM #3Air cleaner as per manufacturer's recommendation. Air cleaner as per manufacturer's recommendation. Air cleaner as per manufacturer's recommendation.
June 12th, 2003 11:10 PM #4
Air cleaner ko every 5K ko pinapalitan kasi generic lang naman. Php 150.00 kina Glenn. Pero nung si afrasay ang bumili Php 140.00 lang. hehehe.
June 13th, 2003 12:05 PM #5
Drain your radiator and refill with new water.
Check grease points, lalo na sa propeller shaft.
June 13th, 2003 12:31 PM #6
if you have not changed pa, the transmission oil, the rear diff oil, the brake fluid, clutch master fluid. have your aircon cleaned, pa power wash mo condenser ng aircon.
Tsikot Member Rank 3
- Mar 2003
- 637
June 13th, 2003 01:15 PM #10
what do you use? may anti-freeze ba or wala? they say kase the one with anti-freeze damages some cylinder heads because of alcohol content.
i use prestone lang.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
