Results 41 to 50 of 217
- Apr 2014
- 74
May 29th, 2014 04:27 PM #41Since it is out of warranty, i guess its better sa labas nalang ipagawa. For sure it will cost you an arm and a leg if jan sa casa but of course its for you to decide.. IMHO
May 29th, 2014 04:32 PM #42
Your first post to this thread was just mockery. You did not really make any contribution, did you?
You were making fun of my misery. I have been very patient with you but this time you have gone too far. And don't give me your pangaasar na hilaw. And I really don't look forward to your replies. Unfortunately, this thread is my concern and I will get to read it.Last edited by _Cathy_; May 29th, 2014 at 04:38 PM.
- May 2012
- 372
May 29th, 2014 04:39 PM #43
May 29th, 2014 04:39 PM #44
popcorn please.
patient with me? so are you saying you are chasing all of my replies to this forum?
now is that a threat above? what are you going to do? ban me? hahahaha.
fun of your miseries? common, your kidding right? you are not the center of the universe.
BTT: i bet its either bearing or something stock up in the condenser fan and/or radiator fan.
May 29th, 2014 04:39 PM #45
May 29th, 2014 04:50 PM #47
Ako need ko din popcorn.
Relaks lang cathy, la naman masama sa first post ni brain_mafia imho. Just stating an observation.
BTT: Kung tappet lang yan (or maybe valve clearance din), no need for top overhaul yan. Pineperahan ka lang nang casa sa pinagssabi nila. Have it checked at other shop, out of warranty na eh. Kuha ka 2nd opinion pero dapat talag puwede mo singilin ang casa kasi wala naman problema nung pinasok mo eh, insist mo na may kapalpakan sila.
May 29th, 2014 04:55 PM #48
May 29th, 2014 04:59 PM #49
hydraulic valve lash adjusters need oil to work. kung di nag-circulate ang oil madre-drain nga yung oil dun sa loob ng adjusters and magkakaron ng tappet sounds (takatak or tik-tik, depends on how severe). engine oil acts as the hydraulic fluid inside the lash adjusters (it is like a piston inside a cylinder with a spring inside) and it is this amount of oil inside that "adjusts" the valve clearance. pag walang oil ang mangyari lang dun e lalaki yung valve clearance kasi nga depleted yung oil sa loob ng hydraulic lash adjusters. now as you said after the oil began circulating again the tappet sounds disappeared. that is normal since again oil went inside the lash adjusters and they started working again. however as you said the casa people said "tope", there is a possibility that since the adjusters ran without oil that they will need replacement, baka may leak na or pwede din mag-seize and hindi na maga-adjust. sabi din nila baka sira ang valves? mangyayari yan pag sobrang laki ng clearance nung hindi nag-adjust yung haydraulic lash adjusters at na-hammer na yung valve stem. the damage will be on the valve stem, not on the valves or pistons (na typically nangyayari pag naputulan ka ng timing belt). anyway if this is the case (damaged valve stems) wala ka kawala sa top overhaul (pwede palit lang ng valves and lash adjusters, and of course head gasket. di naman nag-overheat ang engine mo so di need ang machining.
i am more concerned with the oil not circulating. was it just not enough wherein the lash adjusters ran out of oil, or was it worse and the bearings did not get enough oil? if the case is the later than you are in for a major overhaul, maybe even major parts replacement. i suggest have the casa check your engine thoroughly and if worse comes to worst then sell you car na lang. sorry ganun talaga e. sana naman hindi.
May 29th, 2014 05:03 PM #50
You are so predictable. I know you have been mocking me so I would lose my patience and throw the "abusive moderator" excuse.
You are the first person I banned and I have approval from other moderators. Your ban has been extended to 1 month and that was a group decision
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
