Results 21 to 40 of 58
    Jan 2008
    #21
    Re:Valvoline’s Premium Blue Engine Oil and other CJ-4 Diesel motor Oil.
    Ingat po kayo dito, according to big tribology consultants sa US this is best used for new Diesel Engines, 2007 design and later which conforms with the new US Emission Policy, that require among others the use of diesel particulate filter or DPF.
    The additive mixture and content ( to prolong DPF life) of this new diesel motor oli rating may be detrimental to older design diesel engines.
    #22
    Quote Originally Posted by vlad123456 View Post
    *XTO
    thanks for the recommendation. By the way, what oil do you use? para may reference ako.
    you can't go wrong with shell helix diesel or caltex delo gold multigrade (mahirap na maghanap nito) tried also castrol gtx-diesel, petron rev-x trekker and rimula x pero no 1 priority ko yung dalawa.
    basta follow mo lang palagi ang 5,000 kms max or lesser oil change and definitely tatagal ang 4ja1 mo. dagdag mo pa regular air filter cleaning para di siya mausok. fuel filter change at least every 20,000 kms.
    Apr 2008
    #23
    Quote Originally Posted by speedyfix View Post
    for most of the diesel engines, a 40 weight oil will be best. there are of course some exceptions but unless you own an isuzu that's the rule for most.
    sir speedyfix anu po ang suggested/recomended nyo pag sa crdi engine? ilang liters po? mine was gen3 grx starex.. tia.
    Jun 2008
    #24
    pde paexplain yun viscosity number? thick and thin oil?
    pros and cons of different oil viscosity.
    Jun 2008
    #25
    #26
    Sir XTO
    I take note of the engine oils you mentioned. I'm also a Crosswind owner, non-turbo version.
    Have a question though, would the ones you recommend still good for the Fuego with turbocharged 2.5D 4JA1 engine?
    Salamat.
    Jun 2004
    #27
    http://www.carbibles.com/engineoil_bible.html
    #28
    Quote Originally Posted by Gerbo View Post
    Sir XTO
    Salamat.
    Isuzu recommends their IGMO or Isuzu Genuine Motor Oil for these 1988 circa engines (with turbo or not) so any brands with SAE 40 rating will do (Delo Gold, Silver, Petron HD Hauler, Shell and Castrol monogrades. etc) but because multigrade can give better protection esp during cold starts I would prefer this over the former mura lang naman difference
    btw even with gen 2 (4d56) and 2.5 (4m40) pajeros (with intercooler turbo pa nga) here in tsikot use these types of mineral based multigrades considering 4m40 engine is newer. also the patrol with turbocharged ZD30.
    #29
    Copy sir. For 50,000km oil change na kasi Fuego ko. Salamat.
    Btw, do you know the producer of the proprietary Isuzu Genuine Engine Oil.
    Jan 2008
    #30
    API CJ-4 vs API CL-4/CL-4 plus diesel engine oils.
    http://www.turbodieselregister.com/TDR57_Oil.pdf
    #31
    Jayson's - dealer of isuzu genuine parts in j. abad santos manila confirmed me this. Isuzu Genuine Motor Oil SAE 40 and locally made Caltex (Delo Gold or Silver Monograde) is the same though some tsikoteer noticed that some casa filled the IGMO container with Castrol naman might be possible that some casas use other brands too since majority of them don't allow the owner within their work area.
    Jan 2008
    #32
    CI-4/CJ-4 DIESEL OILS - What's a Guy Supposed to Buy?
    http://www.turbodieselregister.com/t...J4LubeOil.html
    LUBE OIL, RELIGION, SPECIFICATIONS...
    http://www.turbodieselregister.com/t...eoilspecs.html
    Petroleum Based CL-4 Diesel Engine oils in the Philippines:
    1. Petron Rev-X Trekker (15w-40, API CL-4)
    2. Seaoil Deomax (15w-40, API CL-4 by partnership with Paramins, a
    division of Exxon)
    3. Bardahl Power-DI Plus ( 15W-40, API CL-4 plus. from
    Norwegian-AmericanCompany. www.bardahl-ap.com/diesel-engine-oils.php)
    4. Mobil Delvac MX (15w-40, API CL-4)
    5. Pertua Exello (15w-40, API CL-4)
    Dec 2002
    #33
    Guys what do you think of the Shell Helix Diesel Plus. Semi-synthetic. I was planning on using it on our Fortuner 3.0V.
    Jun 2008
    #34
    is the valvoline durablend available locally? who are the distributors?
    #35
    Quote Originally Posted by rossph View Post
    I think "plus" is mineral. yung "ultra" ata yung synth. not so sure though.
    Oct 2007
    #36
    Quote Originally Posted by youngrider View Post
    division of Exxon)
    Sir,
    as per my checking, wala pa po CL-4 plus na rating ang American petroleum Institute(ApI). Only CI-4 plus....the latest is still CJ-4..
    #37
    Thanks for the link, I have lots of Hardisks, Malakas pala yung magnet ng Hardisk. I just injured myself with a pair of these. two magnets even stick between my palm of my hand.
    now I will stick them to my filters.
    May 2004
    #38
    i use Elf 15W40 for my 4gj2TC trooper.
    #39
    5w-40 kaya sa 4ja1 engines . .?
    #40
    Quote Originally Posted by s_quilicot View Post
    looks like ok based from autodata.
which oil is better for diesel??
