Results 1 to 10 of 16
- Sep 2016
- 177
December 8th, 2017 04:03 PM #1I would like to ask if tune up is a process need to be done monthly? Thank you!
December 8th, 2017 04:06 PM #2
its a misnomer..
do clean your air intake filter monthly.
what car do you have?
- Sep 2016
- 177
December 8th, 2017 04:10 PM #3
- May 2017
- 16
December 8th, 2017 04:12 PM #4
December 11th, 2017 08:29 AM #5
just follow the PMS (Preventive Maintenance Schedule) on your manual, if you still have it... if not take your car to a reputable shop and have them check your car and if they're honest enough they'll tell you all the things that needs to be done with your car, imho
- Feb 2014
- 2,694
December 11th, 2017 10:49 AM #6
- 54,205
December 11th, 2017 10:59 AM #7in the old tune-up packages of yesteryear, it included, among others, valve lash check and adjust, spark plugs check, clean and adjust (and put it back in the engine!), ignition timing check and adjust, distributor check, clean and adjust, and the walang kamatayang oil and filter change and air filter clean/change, and other fluids check (transmission oil, differential oil, brake and clutch fluid, windshield wiper liquid. . it also included, in some shops, option to brakes and tires check and clean (additional fees, of course).
with today's electronics-laden cars...Last edited by dr. d; December 11th, 2017 at 11:05 AM.
- Sep 2016
- 177
March 3rd, 2018 09:30 AM #10
Sa car mechanic ko ang definition nya ng tune up ay change oil at throttle body cleaning at kung ano ano pa.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
