Page 1 of 3 123 LastLast
Results 1 to 20 of 47
    Jun 2014
    ano ba yun? sabi ng mamang mekaniko...papalitan daw sa car ko kase sira na...kalerky....di ko naman alam itsura nun....h
    nag me-measure ng airflow na pumapasok sa makina
    sends signal to the ECU
    pag sira yan di maka idle nang maayos ang makina
    Aug 2012
    Mass Air Flow (MAF) Sensor
    Symptoms of Wear or Failure:
    Engine may run roughly or not at all
    Poor performance
    Excessive fuel consumption
    Stalling
    Check Engine Light may come on or blink
    Mass Airflow Sensor
    appearance varies for different brands. normally, the MAF sensor is located after the Air Cleaner and before the Throttle Body.
    Jan 2011
    usually, walang continuity dahil sa alikabok lang. try mo muna i spray ng electronic contact cleaner. pag ayaw pa rin, check the 2 wires inside the sensor, baka napatid lang ang wire, pwede hinang dyan. hope this helps
    Jun 2014
    thanks mga pogi
    Jul 2006
    Quote Originally Posted by shelu View Post
    Are you serious?
    Jan 2009
    Are you serious?
    Was thinking the same thing...
    That's one precision measuring instrument right there. A slight change in ECU reading because of fixing it the wrong way could mean engine hesitation or poor fuel economy.
    Besides, these parts are consumable items... like O2 sensors or your spark plugs. They are meant to be replaced once they've reached the end of their operational life.
    Jul 2011
    pede pala ihinang, bagong kaalaman ba yan?
    Ummm... Bakit hindi pwede solder kung napatid lang wiring?
    Jan 2011
    yes, sirs. pwede ihinang and we have done it before. may wires sa loob ng sensor na pwede ihinang pag napatid lang ang wires. it is bit tricky but very doable. why buy a replacement if you can repair it. tricky dahil pag nahawakan mo yong wires, grounded na. actually, i learned this when the maf sensor of my 98 sentra malfunctioned. nabasa ko sa forum ng sentra club na pwede palang ayusin. nagawa naman at ok na.
    Oct 2013
    Ang bawal hinangin ay yung umiinit na element, parang filament yan sa loob.. Pero kung yung wire lang naman na pang conduct ng signal, pwede yan hinangin..
    Jul 2010
    Sirs linawin ko lang po, di ba yun wire na manipis sa loob filament like yun "fragile" madali maputol lalo di maingat sa paglilinis nito, Itong wire ba sinasabi nyong pwede i-solder? o yun bigger wires na connected dito?
    Posted via Tsikot Mobile App
    Aug 2012
    the sensor contains a thin platinum wire, which can break if handled incorrectly
    if yung "hot wire" sa loob ang hihinangin, maging accurate pa rin ba ang data ng sensor? wala bang effect yung solder sa platinum wire?
    Jan 2011
    ang pagkasabi sa akin, pwede hinangin kahit saan sa dalawa. yong sa maf sensor ng sentra ko, doon sa gilid ang napatid, sa side wall. medyo tricky paghinang dahil pino ang wires at di pwede hawakan. natutunan ko to sa club nisssan sentra. about accuracy, i think its alright as long as it is done correctly. sa akin kasi, lakasan lang ng loob, anyway, papalitan ko na rin lang din, subukan ko munang ayusin. palagay ko, naging ok naman dahil balik sa normal ang gas consumption ng sasakyan.
    Jul 2011
    di ko talaga ma gets, yun ba talagang sensor sa loob yung hininang mo?
    di nahigop ng engine yung naputol na wire?
    malalaman mo naman sir yung accuracy, may tolerance sya na resistance value, need mo ng multi tester/ohmmeter.
    Jul 2006
    Jeez, if the MAF sensor is dead, no point in "repairing" it, or soldering it.
    Thats just a cheap wear and tear part. I would GLADLY spend good money on the insurance of a new OEM sparepart, than having to be stranded on some lonely highway, at night, with my loved ones inside the car, all because my soldered or repaired MAF sensor fcuked up.
    Aug 2012
    magkano ba ang MAF sensor?
    Jan 2011
    Quote Originally Posted by red_one View Post
    almost 2k petot din po yong sensor, nong sentra 98. yup, i agree. there is no better way than replacing the defective part with a new one. i was just sharing how we did it. tayo po kasing mga pinoy, mahilig sa kalikot at butingting sa sasakyan. lalo pag luma na ang sasakyan, kung bago at sagot pa ng insurance, syempre, palit agad ng bago.
    Jan 2011
    Quote Originally Posted by MrQ5 View Post
    hindi po nahigop ng makina yong wire kasi isang side lang po ang napatid. kung natanggal ng tuluyan yong wire, talagang palit na ng bago. tama po kayo sir, malalaman kung accurate pa ang sensor sa pamamagitan ng multi tester.
    Aug 2012
    if back to normal gas consumption ang sasakyan mo, then i think okay ang pagkahinang mo. good thing siguro na sa side ang putol at hindi sa gitna ng hot wire.
    if faulty ang MAF sensor, ito possible na mangyari:
    - Check Engine Light will illuminate
    - Engine runs poorly
    - Vehicle may stall and/or hesitate on acceleration
    - Poor fuel mileage
maf sensor?
