Results 1 to 20 of 31
    Im driving a 96 mitsubishi L200 and the engine is emitting white smoke whenever you take out the oil dipstick or oil cap.
    So i need anyone's advice here on your experience swapping an engine or overhaul. Which is better in terms of lifespan and reliability? What are the pros and cons? Thanks
    Jul 2016
    Overhaul mo na lang basta sa trusted mechanik mo dalhin. Pag change engine hindi ka rin sigurado baka pinoy surplus makuha mo and papa change engine ka pa sa car registration.
    Sent from my SM-J500G using Tsikot Forums mobile app
    i agree with overhaul:
    1. you know that the finished product is in good condition;
    2. no need to go to LTO for change of engine hassle.
    agree ako sa overhaul
    madami na na bihasa sa technicalities ng 4d56 dito sa atin. medyo hanap ka lang ng reputable na mekaniko
    Oct 2014
    Ano ang mga pinapalitan sa engine overhauling? Sorry for my limited knowledge about engine.
    Jul 2016
    Quote Originally Posted by Gian Paulo View Post
    Kung dukut lang sir piston ring. Valve seals. Gaskets. Pag major overhaul. Pistons. Piston ring. Engine bearing. Liner. gaskets at diko na malala iba
    Apr 2008
    Depends on what kind of overhaul. Kung top overhaul lang, mura lang. But a general overhaul may sometimes cost more than a surplus 4D56 engine. Good opportunity for a power upgrade too. 😁
    Sent from my SM-G900I using Tapatalk
    Jul 2016
    Go for oem parts sir pag tight budjet ok din yung PT brand na piston, piston ring and liner. Sa bearing ok yung daido.
    Nov 2004
    I was quoted 60k for overhaul ng 4m40.
    Dinala ko kay Boy Romero, inabot lang ng 20+k lahat ng trabaho labor materials.
    If ok ang marikina antipolo area, try mo inquire
    0916-5827200
    Boy Romero
    Dati sya Mechanic sa Mitsubishi then Toyota. 20years casa experience. Shop nya sa garage nya kaya reasonable maningil at may tawad pa. Kumpleto sa gamit from obd pati pang baba ng engine.
    From regular pms to general engine overhaul pati transmission matic or manual ginagawa nya.
    Sent from my LG-H870DS using Tapatalk
    Quote Originally Posted by halimaw View Post
    0916-5827200
    Boy Romero
    Sir top overhaul (Dukot) ba or full overhaul ginawa sa iyo? Ilang araw ginawa?
    Oct 2017
    Pa advice ako sir. Newbie po ako sa deisel engine
    2008 Captiva po unit ko
    Mukhang need overhaul may black smoke na kasi kahit naka idle lng.
    Or baka meron ho kayong ma suggest na pwede ko gawin para hindi e overhaul.
    Need din po ako advise san maganda mag pa check las pinas Daang Hari po location ko sana yung malapit lng
    Salamat po
    Quote Originally Posted by JamesD07 View Post
    Salamat po
    Have your fuel injection system checked first.
    Sent from my SM-T705 using Tsikot Forums mobile app
    Salamat po
    Mhkhang tune-up po ang kailangan pag black smoke. Diesel calibration to be exact.
    Sent from my SM-J400G using Tapatalk
    CRDi engine? Maybe a bad injector.
    Jun 2008
    Look for a shop that can do compression test to your engine. The result will guide you if the engine needs piston overhaul, top overhaul or non at all. Black exhaust gas out of the tail pipe is not a guarantee that your engine needs overhaul. It might be one or combination of defect in the charge air system, egr system or fuel system that causes black smoke.
    Check for the presence of white smoke coming out of the oil filler. This is an indication of a blowby piston rings but not always.
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2008
    QC area kasi ako kaya hindi ako familiar sa location nyo. But the most well known diesel centers that can help you would be Central Diesel, Malabon Diesel and Berrima Diesel. Perhaps you can contact them over the phone and see what they can do for you.
    Is there any difference in terms of performance and fuel consumption? Or is black smoke your only concern? There are numerous causes that can contribute to black smoke. Also have you done all the basics? Replace air, oil and fuel filters, replace all fluids, clean the EGR and, perhaps also the exhaust?
    Quote Originally Posted by GTi View Post
    agree, i would be alarmed if the smoke is on the white side.
    basics muna.
Need advice on 4d56 engine: swap to surplus or overhaul?
