Have your fuel injection system checked first.
Sent from my SM-T705 using Tsikot Forums mobile app
Look for a shop that can do compression test to your engine. The result will guide you if the engine needs piston overhaul, top overhaul or non at all. Black exhaust gas out of the tail pipe is not a guarantee that your engine needs overhaul. It might be one or combination of defect in the charge air system, egr system or fuel system that causes black smoke.
Check for the presence of white smoke coming out of the oil filler. This is an indication of a blowby piston rings but not always.
Sent from my NX549J using Tsikot Forums mobile app
QC area kasi ako kaya hindi ako familiar sa location nyo. But the most well known diesel centers that can help you would be Central Diesel, Malabon Diesel and Berrima Diesel. Perhaps you can contact them over the phone and see what they can do for you.
Is there any difference in terms of performance and fuel consumption? Or is black smoke your only concern? There are numerous causes that can contribute to black smoke. Also have you done all the basics? Replace air, oil and fuel filters, replace all fluids, clean the EGR and, perhaps also the exhaust?
Sent from my SM-G900I using Tapatalk
Pag change engine hindi ka rin sigurado baka pinoy surplus makuha mo and papa change engine ka pa sa car registration.
Pag change engine hindi ka rin sigurado baka pinoy surplus makuha mo and papa change engine ka pa sa car registration Audacity Find My iPhone Origin
Rebuild. Eto reputable engine rebuilder.
G.U. Engineering - Your Engineering Service Partner
Yan bumuo ng 4JA1 ko. Daig pa brand new manakbo. After nagawa tanung ng manager ng isang shop kung gusto ko ibenta-may interesado daw![]()
