Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    #21
    Quote Originally Posted by JamesD07 View Post
    Pa advice ako sir. Newbie po ako sa deisel engine
    2008 Captiva po unit ko
    Mukhang need overhaul may black smoke na kasi kahit naka idle lng.
    Or baka meron ho kayong ma suggest na pwede ko gawin para hindi e overhaul.
    Need din po ako advise san maganda mag pa check las pinas Daang Hari po location ko sana yung malapit lng
    Salamat po
    Have your fuel injection system checked first.
    Sent from my SM-T705 using Tsikot Forums mobile app
    Jun 2008
    #22
    Look for a shop that can do compression test to your engine. The result will guide you if the engine needs piston overhaul, top overhaul or non at all. Black exhaust gas out of the tail pipe is not a guarantee that your engine needs overhaul. It might be one or combination of defect in the charge air system, egr system or fuel system that causes black smoke.
    Check for the presence of white smoke coming out of the oil filler. This is an indication of a blowby piston rings but not always.
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2008
    #23
    QC area kasi ako kaya hindi ako familiar sa location nyo. But the most well known diesel centers that can help you would be Central Diesel, Malabon Diesel and Berrima Diesel. Perhaps you can contact them over the phone and see what they can do for you.
    Is there any difference in terms of performance and fuel consumption? Or is black smoke your only concern? There are numerous causes that can contribute to black smoke. Also have you done all the basics? Replace air, oil and fuel filters, replace all fluids, clean the EGR and, perhaps also the exhaust?
    Sent from my SM-G900I using Tapatalk
    #24
    Quote Originally Posted by GTi View Post
    agree, i would be alarmed if the smoke is on the white side.
    basics muna.
    #25
    Salamat po
    Mhkhang tune-up po ang kailangan pag black smoke. Diesel calibration to be exact.
    Sent from my SM-J400G using Tapatalk
    #26
    CRDi engine? Maybe a bad injector.
    Feb 2019
    #27
    Pag change engine hindi ka rin sigurado baka pinoy surplus makuha mo and papa change engine ka pa sa car registration.
    Feb 2019
    #28
    Pag change engine hindi ka rin sigurado baka pinoy surplus makuha mo and papa change engine ka pa sa car registration Audacity Find My iPhone Origin
    #29
    Quote Originally Posted by lala31 View Post
    unless that surplus engine has a bulletproof provenance, i'll probably have my old, tired engine overhauled na lang.
    #30
    I'd favor the same route, doc.
    #31
    Rebuild. Eto reputable engine rebuilder.
    G.U. Engineering - Your Engineering Service Partner
    Yan bumuo ng 4JA1 ko. Daig pa brand new manakbo. After nagawa tanung ng manager ng isang shop kung gusto ko ibenta-may interesado daw
Need advice on 4d56 engine: swap to surplus or overhaul?
