I appreciate those folks who take time to properly upgrade their exhaust systems. The expenses tied to it and the effort spent makes it a passion of sorts.
However, there are those who take the half-baked approach and just ends up with a loud and annoying car.
ah oo nga no? from the very beginning hindi ko napansin yun ah
tulungan nalang natin si TS to do the proper mods, para hindi na dumagdag sa mga puro ingay lang.
I used to remember a co-worker who asked my opinion about his plan to purchase a City and spend another 100k+ for body kits, exhaust mods, etc. I told him to just go buy a Civic.![]()
just for a change in sound, TS might just consider to install a muffler tip. it's a lot cheaper and easy to install kasi sa dulo lang ng tailpipe i-attached. he can even select exhaust tips of various shapes or those bluish burned tips na nagkalat ngayon. for "macho" effect, maybe a 6" diameter tip will do
btw, i had modified the exhaust of my monty with performance and sound enhancement in mind. the stock 2" diam exhaust of montero is not that restrictive, but i opted to replaced it with all stainless steel 3" downcomer, 2.5" midpipe to tailpipe and matched with oval shape exhaust tips for aesthetics. the stock muffler was replaced with a bit bigger magnaflow muffler (single in/dual out) i bought abroad. spent total 25k+ for the materials/install. sa sound, since mas bigger yung muffler, result was mas deeper yung tone lalo kapag naka-idle. at cruising speed, walang pinagkaiba sa stock. inside the cabin medyo naingayan si wifey sa una pero since daily drive niya kapag nasa overseas ako, nasanay na. sa performance, i think may improvement din naman based sa butt dyno ko. i don't have figures to show kasi di naman ako nagpa-dyno run before and after the install. di pa uso nun ang ECU remap like ecutek, if meron na nun di na ako nagpa-modify ng exhaust, at 30k may kasama ng dyno, mas malaki pa yung power gain...its my next project
i don't know about jasma certified mufflers. i know about magnaflow, borla, flowmaster, cherry bomb muffler brands used ng mga amerikano. locally, meron borla meron kay a-toy bodykits and mga catback exhaust pipings. sa speedlab marami na rin installations ng mga exhaust modifications. you have to pay premium nga lang for the quality and workmanship...
i had my exhaust mod installed by by ELAA shop in mandaluyong. the guy name is Dante +09153429523/+09326019683. pulido naman gumawa, more than 3 years na mod ko so far so good. a lot of our club members na nagpamodify ng exhaust si Dante gumawa. he can even fabricate a muffler, exact copy ng mga known brands![]()
nice pipe setup! your fabricator knows what his doingit starts at 3" and tapered to smaller diameter along the way, so when the exhaust gas reached the smaller diameter section it increase its velocity (like a tapered garden hose sprayer), plus it acts like a vacuum that sucks the gas behind thus helping the engine to evacuate the exhaust gas from the combustion, aaaand if you advance the opening of the intake valves it even sucks the incoming air at the intake manifold during the overlaps.
i have the same setup on my weekend car btw, thou it starts at 2.5" and tapered to 2" at mid section
To ts pag gusto mo talaga maingay na muff hanap mo kakimoto muffler sa surplusan or meron din ata sa olx imported yan. Pag buzzy sinabi na nila go with jasma sa surplus. Ok din sa muffler land exhaust mga muffler they use tig weld. Yung sakin gawang nodalos lang na oval open type. Buzzy sound lang sya kasi mahaba resonator ko on a blacktop engine.
Sent from my SM-J500G using Tsikot Forums mobile app
Ano yung "buzzy" sound? Tunog bubuyog?
Kaya nga nagtanong Sir kung anu maganda. Gusto mag enhance ng sasakyan, di ko alam yung term, so nagtanong ako. Diko alam kung bakit madame galet. Diko balak mag ingay, kase nga na engganyo ako dun sa bro in law ko, naka muffler pero masarap sa tenga yung tunog, ika nga "macho" "pogi", may iba pa ba term? di ako expert sa kotse pasensya naman ho.
Meron ba kayo mare-recommend na good muffler/exhaust repair shop, sta. rosa area?
TIA
mga bossing, ung auto ko na vti 96, naka down pipe..gusto ko sana ibalik ng stock pipe para di maingay eh naka tri Y headers daw, di ba talaga kaya ng stock pipe ito, kaya kailangang naka 2.5' na mufler daw para di maipit makina. need advice.. gusto ko din kasi tahimik hehehe
best i can recommend. put back the original headers and exhaust system. if no more. can be bought cheap from others because almost everybody was taking them out. next step but a little bit more expensive than stock vti is to look for an SiR stock exhaust. slightly bigger diameter pipe than the vti stock pipe.
