Page 234 of 330 FirstFirst ... 134184224230231232233234235236237238244284 ... LastLast
Results 4,661 to 4,680 of 6586
    Apr 2016
    #4661
    Quote Originally Posted by Offroad_Goals View Post
    Sa amin, we use semi-synthetic shell oil (Diesel) and we change it every 4.5k-5.5k (On average 5k) whenever may budget at may oras na but usually we don't let it go as far as 6k. We maintain to change it every 5k kilometers or a few hundred more.
    ako since weekend lang nagagamit car ko i tend to change it via months and not via KM minsan for like 3 months 1k lang natatakbo ko pero its ok i mean if alaga sa langis ung kotse meaning alaga ung makina so i think ill have a change oil in feb pa :D since fullsynth na gamit ko
    Oct 2014
    #4662
    Quote Originally Posted by iameldrin View Post
    Is it every 6 months even if less than 5k km run and using Full synthetic?
    Apr 2016
    #4663
    Quote Originally Posted by Gian Paulo View Post
    actually there are some that argues about it some say follow the KM and some is which ever comes first.
    if its FS oil there are some brands that will last around 10k up to 15k it depends on what they are claiming.
    For me kasi, since minsan lang nagagamit ung car and mostly city driving lang I follow the month based change oil pero wala din ako balak sundin like for
    Mineral its like 3k-5k or 3months
    Synthetic Blend 7k or 5 months
    Fully Synth 10k-15k or 10monthe to 1 year
    Ill still gonna do change my oil after 4 to 5 months since fully synth siya, it might be wasteful for others but I care for my engine so thats why
    Aug 2016
    #4664
    well at least you change the oil, some people (some na kakilala ko) think na basta tumatakbo, and malinis ang kotse, eh hindi na kailangan i-maintain.
    tuloy, nasira ang makina. so much sludge buildup that the engine wasnt able to lubricate itself properly the cylinder walls warped, and the engine self destructed...
    Oct 2016
    #4665
    Hi Guys....just want to ask sana mga expert. Malapit na naman ako mag-change oil...dati gamit ko 10w40 Shell HX7 blue. Tapos nag lipat ako ng 15w50 (un-intentional yun) kasi iniwan ko lang sa trusted mekaniko ko car ko para mag-pachange oil...nilagay nya ay castrol magnatec.
    Eh napansin ko parang naging sluggish auto ko at lumakas gas fuel consumption ko.
    Dati kasi hindi nababa sa 3/4 ang needle ko sa Php600 one week na gamit *14KMS roundtrip travel.
    Kaya parang gusto ko bumalik sa 10W40
    Ano ba okay na gamitin?
    Ito yung mga pinagpipilian ko:
    Mga pinagpipilian ko ng oil ay:
    1. MOTUL H-TECH 100 PLUS 10W40 API SM/CF
    2. ULTRON RALLYE SAE 10W-40 API Service SM/CF
    3. Shell Helix HX7 10W-40 API SN/CF
    4. Idemitsu Extreme
    10W40 SN/CF Semi Synthetic
    Ang auto ko pala ay 1997 Mitsubishi Lancer 1.6 GSR MT.
    Wala na manual eh.
    MARAMING SALAMAT
    Hx7 pinaka maganda sa list mo bro
    Sure ka ba magnatec nilagay? Did you see green or white bottles? White ones are castrol gtx and are mineral. The magnatec oils are very good. Ano kaya viscosity ng nilagay ng mechanic?
    Oct 2016
    #4667
    uy salamat stockengine sa reply...ang bilis...yun nga talaga nasa toplist ko sa mind ko lang...nag-add lang ako baka kasi sakali mas may okay pa.
    Pahabol na katanungan kung okay lang....oks lang naman cguro HX7 langis ko kahit XCS ang gas ko wala naman siguro problema? Habol ko kasi sa Petron yung points
    thanks ulit
    Engine oils are for lubrication and is not mixed with fuel. Hehehhe
    Go for any fuel. Basta palet fuel filter regularly 40k..
    Oct 2016
    #4669
    salamat stockengine sa reply....really appreciate it.
    #4670
    mga sir tanong lang kung ano magandang fs oil for tucson 2011 gls.
    Quote Originally Posted by burnik View Post
    Most fs oils conform to different requirements. Engine oils are of diesel and gasoline varieties.
    In your owners manual it will say which type of oil it requires.
    Question is... is your tucson diesel or gas?
    #4672
    thanks sa mabilis na reply sir. gas po yung tucson ko.
    Aug 2010
    #4673
    between this oil, ano mas preferred nyo gamitin pang diesel?
    Mitasu Turbo Diesel 15w40 - 1200/Gal
    Mitsau Diesel Ultra 5w40 - 1700/Gal
    Top1 Hd Plus 10w30 1575 / 5L
    Zic x7 10w30 - 1500/4L
    Jan 2009
    #4674
    Just to be more accurate, there are motor oils that are designed for both gas or Diesel engines. These would have an API marking such as SM/CF. In simplest terms, it means that it is suitable for gas engines that require an API SM oil as well as Diesel engines that require API CF. Assumption here is that you're already using the correct viscosity.
    #4675
    Quote Originally Posted by igiwtf View Post
    6L yung Zic X7 10w30
    Aug 2010
    #4676
    any feedback on Zic x9000 and x7000 both in 15w40?
    is this better than the X7?
    Mineral oils...
    Completely mistaken. X7000 and x9000 are hdeos from zic. FS 15w40s.
    Dec 2016
    #4679
    Mineral all the way. I'd rather have new oil put in more often than have old oil for longer.
    #4680
    Quote Originally Posted by trucker111 View Post
    API CJ yung X9000
    API CI-4 yung X7000
Mineral , semi synthetic or fully synthetic?
