Page 367 of 658 FirstFirst ... 267317357363364365366367368369370371377417467 ... LastLast
Results 3,661 to 3,670 of 6580
    Jul 2015
    #3661
    Quote Originally Posted by radz15 View Post
    Any adventure or crosswind owners here using zic up 10w40?
    Yan ba yung black container green label? Yan ang gamit ng relatives ko fleet taxi business adventure. urvan. Mabilis daw kasi lumapot delo gold kaya lumipat ibang brand.
    Jul 2015
    #3662
    Which specific oil is this? Where is it available?
    editedit
    RV 10w30 and Shell 10w30
    Mas quiet engine using rv 10w30 for our innova. Sometimes i double check baka nakaoff engine yun pala tahimik talaga. Tried delo gold ultra pero ingay engine.
    Sa shell ok din pero kaso mausok. Will check the container parang CF ata API
    #3663
    Quote Originally Posted by midnytwarrior View Post
    1. G-DLD-1, API CF-4, CF = API Rating(CF-4;CF) = additive requirements (in layman's terms) para sa protection or minimum additives required para sa engine
    2. xxWxx = meaning to say, yun viscosity ng oil or lapot o labnaw ng langis
    Usually magkahiwalay sila since iba ang specifications or "petaining to"
    Ano ba ang naka lagay sa owner's manual?
    yun API rating is yun "minimum" na engine oil additives na required para mabigyan ng protection ang engine. C=Combustion/Commercial (para sa diesel engines); Followed by another alphabetical character(the farther from letter "A" means better additives) which is letter "F". Most recent is letters "H(1998),"I"(2001); "I+"(2004) or "J"(2006)
    xxWxx = weather grade. sample is 15W-40. W=winter grade. Meaning pag may "xxWxx" meaning may "Winter" Grade at "Summer" grade combined. "15W" means the oil will not solidify -15 deg Celcius (winter) and "40" (summer) means that the oil can maintain it's "viscosity" at 40+ deg Celcius ambient temperature.
    So, for example, pag sinabi sa manual na "15W-40, API CF-4" meaning yan ang pinaka minimum na reuired na oil para sa sasakyanb mo.
    Going lower than "CF-4" means less additives para sa engine; going "thicker" than "15W-40" such as 20W-50 or SAE 40 means mas malapot ang langis then mahihirapan ang engine mo, which will lead to breakdowns.
    Thanks sir sa napakadetailed at simpleng explanation. Wala pong nakalagay na xxWxx na reco rating sa manual. So basically since CF-4 ang nakalagay sa manual, I should use CF and up. As to the viscosity, immaterial yung 1st xx kasi wala naman tayong winter, right? Then for the 2nd xx, better siguro 40 kasi global warming na. Pumapalo na ng ~40deg kapag summer dito sa atin, right?
    Is there something na 5W40? Salamat
    Jul 2015
    #3664
    Quote Originally Posted by sphinxz View Post
    Maganda maexperience mo lahat. Try mo lahat ng available viscosity para malaman mo saan ok.
    Ginawa ko dati yan. Mas gusto 10w30 innova.
    #3665
    Then I'll start with 10w30. Parang consensus naman lahat dito for that type. sa brand naman, are there some brands I have to watch out for? Thanks
    Apr 2014
    #3666
    You welcome sir.
    Normally naka indicate din yun SAE viscosity rating na required na engine oil sa manual.
    Ang mga engine manufacturers ang nag dictate ng mga oil viscosity at additive requirement para sa engine. So pag hinde nagamitan ng required na viscosity at additive yun engine eh magkakaproblema in the long term.
    What I mean here is, kaya may viscosity requirement is para sapat ang thickness ng oil para maka circulate sa loob ng makina and mag provide ng tamang lubrication.
    Yes meron 5W-40 na grade. Not sure about for diesel engines, pero recently may nakita ako na TRD Motul na 5W-40 diesel engine oil.
    But better check mo yun manual para makita yun mga allowed na oil viscosity na pwedeng gamitin sa engine.
    BTW, ano year model ng sasakyan mo, ilan na mileage at ano yun oil na gamit mo dati?
    You welcome sir.
    Apr 2014
    #3667
    Basically, all oils are the same, but they are not created equal.
    Try natin ganito when you search for engine oil:
    1. Oil requirement for your engine
    2. Price/budget
    3. Start with brands like Shell Rimula/Caltex Delo
    4. Availability
    5. Reputable store - marami kasi sumasalisi na fake oils pati subpar brands na exaggerated ang specs sa mga local auto supplies.
    2. Price/budget
    4. Availability
    Dec 2009
    #3668
    Quote Originally Posted by amoyligo View Post
    Parehas kasing black container and green label yung zic up 10w40 saka yung zic rv 10w30. Alin po kaya dun sa dalawa gamit ng relatives nyo?
    Jul 2015
    #3669
    Tinanong ko ngayon yung 10w40 ang gamit for fleet adventure and urvan
    Yan rv 10w30 gamit ko sa innova. Tahimik talaga engine.
    Apr 2012
    #3670
    Maganda yung RV 10w30 yan gamit ko sa Grand Starex.
Mineral , semi synthetic or fully synthetic?
