Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 148
    Sino na nakagamit?
    Sabi sa ibang forums ok daw e.
    Once a year lang kasi ako magpa change oil kahit medyo mataas na mileage ng oto ko (almost 85K na). Bibihira ko na rin lang kasi gamitin. Last year 5K kms lang tinakbo ko. Iniisip ko maglagay nito para added protection na rin sa engine. Lasts up to 4 oil changes daw e. 1700 ata sa speedlab.
    Wadayatink?
    Dec 2009
    i tried both the ceratec and liqui moly... yung ceratec ginamit ko sa diesel yung liquimoly sa gas namin...
    there will be improvement sa FC...
    in my opinion the ceratec saved us from a total engine overhaul when one vehicle overheated due to hose leaking... it was so hot the engine cover melted!!
    sa BITOG forums abroad, ok naman mga reviews nila....
    Thanks miko. Diesel pala ang ginamitan mo. May iba kasi nagsasabi na may issue daw sa spark plugs kung sa gas ginagamit.
    Basa basa din ako sa Bob Is The Oil Guy.
    Oct 2011
    Hindi ko pa nasubukan pero nakikita ko ito sa car show.
    Dec 2009
    Quote Originally Posted by robot.sonic View Post
    if madali lang palitan spark plug mo... pwede naman.. meh mga vehicle kasi na super hirap palitan spark plug kaya hastle pag na foul dahil sa ceratec
    Nov 2004
    wala ko makita ceratec kaya sinubukan ko muna sa pajero fm 4m40 diesel, liquimoly mos2 * P550 300ml pede upto 7L oil capacity, mas lalu pumino at tumahimik engine even bagong start dati mejo may konti gaspang need muna idle ilang secs-min para mas pumino ngayon makinis agad pati pag tuwing sipa ng aircon compressor yung konti palag di na ramdam.
    Gusto ko din masubukan liquimoly ceratec eto ata latest nila. Malaki kaya difference sa benefits vs mos2? Mejo mahal din kasi 550 vs 1700. Same 300ml?
    Sent from my iPhone using Forum Runner
    Jul 2011
    Sir saan po kayo nakakabili ng ceratec, galing ako ng ACE sa MOA kahapon wala akong nakita.
    Quote Originally Posted by Manilablock View Post
    Try checking the Liqui Moly site for dealer details:
    Liqui Moly Philippines
    I was thinking of this Certec a few months ago but i'm still waiting for more concrete feedback/results from those who used the product locally.
    Si CB also used the Mos2 and seems happy with it.
    sa speedlab na website meron sila.
    Nov 2004
    Mas ok ata pagsabayin mos2 at ceratec? Parehas maganda magagawa sa engine
    Ang ceratec nag bind sa metal mismo? Upto 40-70k mileage protection?
    Quote Originally Posted by miko101130
    hindi kalokohan ang engine oil additive o fuel additive,, napapa sama lang dahil majority of these products are not really able to deliver their claims. So the mindset of those who were unfortunate to buy those non performing additives will be biased..
    If you do your research and homework first, your money will be well spent
    MOLYBDENUM BASED ADDITIVES - search nyo sa net regarding molybdenum additives para ma enlighten ang mga nasa dilim pa!!
    *Moly has a very low coefficient of friction even in the higher heat ranges to 750 degrees F
    *Major oil companies and most large industries are depending on oils and greases fortified with Moly to extend the service life and reduce maintenance on aircraft, trucks, compressors, tractors, ships and automobiles. Properly used it can double the operating life of equipment and reduce maintenance as much as 60%. Another small plus for Moly in these days of fuel prices, is that an engine treated with Moly usually obtains 10% to 25% better fuel mileage. Moly reduces friction in an engine up to 60%.
    *It possesses the properties of being able to withstand extremely high load capacities (400,000 psi). It is chemically stable, has a very low coefficient of friction (0.05 to 0.09 in powder form) and has thermo-stability over 2,000°F. All of these properties are essential to reduce metal to metal contact and thereby reduce friction, heat, and wear
    BORON NITRIDE OR CERAMIC BASED ADDITIVES- these additives are among the latest if not the best performing additives that has scientific data and background to back its claims...
    *Temperature stability of the
    ceramic particles : To +1,200 °C
    *A ceramic-metal layer formed during action of an additive makes for enhances tightness of rings and a tube
    *Durability of ceramic-metal layer corresponds to coaled surfaces and in under guarantee for distance of 70 000km
    * Excellent Lubricating Properties due to low Coefficient of Friction at 0.15 to 0.70
    Good Chemical Inertness
    Electrical Insulator
    Thermal Conductor (result: better heat dissipation)
    High Temperature Stability, 1000o C in Air, 1400o C in Vacuum and 1800o C in Inert gas
    Low Thermal Expansion
    Low Dielectric Constant
    High Load bearing properties
    Non-Wetting: hBN is not wetted by Glasses, Salts and (most) metals, therefore it provides strong resistance to chemical attack Easy Machineability (in hot pressed state). Complex shapes can be machined from hot pressed structure.
    one treatment will last you around 40,000kms to 70,000 kms... boron nitride is virtually indestructible once it binds into your engine metal parts
    Dec 2009
    personally hindi ko sila pinagsabay... either Mos2 o ceratec...
    sa mos2 noticeable talaga yung added smoothness kaya mas gaganda FC .... ceratec in my opinion is more of reducing ng friction of internals ng engine...
    in the long run kase mas mura ceratec, kase good for 70,000 kms....
    tsaka german made eh,hahaha... u know how germans think "perfection"
    Matry nga yung ceratec. Mukhang maganda yung recommendation ni miko hehe
    how different is this from GTOil? I mean kasi parang same sila ng mga claims and same ng mga testimonies ng users.
    don't mean disrespect I just want to differentiate para malaman ko kung paano maa identify kung snake oil or legit ang product.
    Nov 2004
    Di ba "mos2 inside" na engine mo paps? Dagdagan mo sabay ceratec? :-)
    Sent from my ONDA V712 HD using Forum Runner
    Nov 2004
    Quote Originally Posted by Bin Diesel View Post
    Dunno about gtoil boss... pero itong mos2 at ceratec meron basis at active components known to be beneficial sa contact moving metal parts yun nga moly at boron, even hyundai and other car manufacturers use these for better protection and performance.
    Nov 2004
    Quote Originally Posted by miko101130 View Post
    May nabasa ka na ba paps na pede sila pagsabayin?
    Jul 2006
    Mos2 user here for almost 3 years, no problems so far.
    Been reading about this, yung Mos2 wala sa site ng LM Phils. Phased-out na ba yun?
    Jul 2006
    ^ Are you sure?
    See here: Liqui Moly Philippines
    ^ Are you sure?
    I mean yung additive. Yung nasa pic ni halimaw.
Liqui Moly Ceratec
