Results 1 to 10 of 148
January 19th, 2013 10:07 PM #1
Sino na nakagamit?
Sabi sa ibang forums ok daw e.
Once a year lang kasi ako magpa change oil kahit medyo mataas na mileage ng oto ko (almost 85K na). Bibihira ko na rin lang kasi gamitin. Last year 5K kms lang tinakbo ko. Iniisip ko maglagay nito para added protection na rin sa engine. Lasts up to 4 oil changes daw e. 1700 ata sa speedlab.
Wadayatink?
January 20th, 2013 08:02 AM #2
i tried both the ceratec and liqui moly... yung ceratec ginamit ko sa diesel yung liquimoly sa gas namin...
there will be improvement sa FC...
in my opinion the ceratec saved us from a total engine overhaul when one vehicle overheated due to hose leaking... it was so hot the engine cover melted!!
sa BITOG forums abroad, ok naman mga reviews nila....
January 20th, 2013 12:33 PM #3
Thanks miko. Diesel pala ang ginamitan mo. May iba kasi nagsasabi na may issue daw sa spark plugs kung sa gas ginagamit.
Basa basa din ako sa Bob Is The Oil Guy.
January 20th, 2013 11:47 PM #5
January 21st, 2013 12:13 AM #6
wala ko makita ceratec kaya sinubukan ko muna sa pajero fm 4m40 diesel, liquimoly mos2 * P550 300ml pede upto 7L oil capacity, mas lalu pumino at tumahimik engine even bagong start dati mejo may konti gaspang need muna idle ilang secs-min para mas pumino ngayon makinis agad pati pag tuwing sipa ng aircon compressor yung konti palag di na ramdam.
Gusto ko din masubukan liquimoly ceratec eto ata latest nila. Malaki kaya difference sa benefits vs mos2? Mejo mahal din kasi 550 vs 1700. Same 300ml?
Sent from my iPhone using Forum Runner
- Jul 2011
- 1,711
January 21st, 2013 06:49 AM #7Sir saan po kayo nakakabili ng ceratec, galing ako ng ACE sa MOA kahapon wala akong nakita.
January 21st, 2013 09:17 AM #8
Try checking the Liqui Moly site for dealer details:
Liqui Moly Philippines
I was thinking of this Certec a few months ago but i'm still waiting for more concrete feedback/results from those who used the product locally.
Si CB also used the Mos2 and seems happy with it.
January 21st, 2013 12:46 PM #10
Mas ok ata pagsabayin mos2 at ceratec? Parehas maganda magagawa sa engine
Ang ceratec nag bind sa metal mismo? Upto 40-70k mileage protection?
Originally Posted by miko101130
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
