Results 11 to 20 of 41
- Jul 2011
- 584
December 30th, 2011 09:11 AM #12
- Apr 2006
- 351
January 1st, 2012 09:50 AM #13
- Mar 2012
- 1
March 21st, 2012 02:00 PM #14I had gone through the post.; I did the first oil change at 15k km when yearly 20k km was recommended. Now, In the next oil change we did at 20k km. This was good enough for the CRDI car with VGT. Please produce some more attachment links for the detailed view of the topic? Thanks in advance.
quick oil change coupons
recommended oil change interval
March 28th, 2012 11:45 AM #15
April 2nd, 2012 10:11 AM #17
How about sa 2010 toyota innova diesel? I know na need ang CI-4 motor oil sa 2KD-FTV as well pero ang question ko is can I use petron's TREKKER oil? I checked the bottle and it says na it's a CI-4 type of oil. Ayoko kasi masalinan ng ibang langis eh. Baka in the long run, using the wrong oil will give me a headache..
- Jun 2008
- 1,741
April 2nd, 2012 10:41 AM #18Kung ang sabi ng label ay CI-4 class ang langis eh syempre compatible yan sa makina. Wag mo ipaghalo ang langis, drain all the old oil and changed full volume of fresh lube oil.
Regarding the 20K change oil posted above. Yes you can do that if you want to destroy or retire your engine earlier Kidding aside, dapat 5K Km lang ang change oil if the car usage is mostly in Metro Manila regardless of car brand. The metro manila traffic condition is considered as "extreme driving condition". HTH
April 2nd, 2012 11:24 AM #19
April 2nd, 2012 02:07 PM #20
if your using petron trekker for a diesel engine, tapos VIC filters gamit mo... 5k is really the maximum at which you should change your oil,,,
*Petron trekker CI-4 has no available Material data sheet or any product information sheet regarding the contents of the oil
(personally i dont recommend this for personal vehicle use) there are a lot of better oils out there!!
*Vic filters are not good filters if you intend to prolong your engine like it just rolled out of your casa... there are also a lot of alternatives filters out there which is 200% better than VIC, examples(baldwin/fleetguard/purolators/bosch)
i suggest you read the REMOTE BYPASS OIL FILTRATION THREAD...
http://tsikot.com/forums/engine-fuel...tration-79219/
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
