baldwin/fleetguard and purolators have impressive micron rating for its filtering capabilities.. you can easily go 10,000kms...
the best combination would be outstanding filters and oils with CI-4/SL rating of which must have at least a minimum of 10 TBN...the important thing is that the oil you will choose should have a posted product data sheet
so that you know what you're paying for and what you're actually getting...
definitely you will be able to SEE and FEEL the difference...
mga bro, can you share the name's store & location of fleetgard and purolators?
TIA po mag-share...
Buhayin ko lang thread nato. Just curious about the company issued innova diesel that is religiously maintained by toyota shaw. The casa replaces the engine oil(toyota brand full synthetic) fully only every 10,000 kms. However, every * 5,000 kms interval, what they do is to replace the oil filter and top up only. And this is being done during the warranty period by the way. So it comes out na mura na din overall. Just sharing my actual experience.
ako castrol oil o mobil..ayos din naman performance nya. di ganu naitim ang langis kapag updated sa pag change oil..good maintenance lang talaga kelangan.
using Delo 400 sa kia sportage crdi - every 5k kms oil change
using Royal Purple 15w40 - every 10k kms oil change , every 5k kms OEM oil Filter change
Update lang mga sir.
Alin po mas maganda sa crdi engine. 2014 Accent Hatch po unit ko.
Fully Synthetic - Change oil every 10k km (top up and change oil filter at 5k km)
or
Semi Synthetic - Change oil every 5k km?
TIA
using fully synthetic, semi synthetic, or conventional oil will not alter oil change intervals.
Fully synthetic interval is 10k w/ top up of a liter & change oil filter at 5,000. At least that is the recommendation by the Casa. But if I were you, if your daily route takes you to high traffic areas & frequently gets stuck in traffic, do it every 5,000 (which means the better option is Semi synthetic). Reason being your mileage maybe low, but engine running time is long.
Ako kasi, daily route is expressway & star tollway, around 750 km a week & 24 or 25 hours running time per full tank a week. May traffic, pero konti lang sa Alabang or Parañaque. Usually open highway or open free roadways.
Sorry mejo OT,
*bloowolf, db accent hatch din unit mo? Casa PMS ka pa rin ba o sa outside na? TIA
Sorry mejo OT,
