Results 21 to 40 of 41
    Jan 2008
    #21
    Quote Originally Posted by miko101130 View Post
    if your using petron trekker for a diesel engine, tapos VIC filters gamit mo... 5k is really the maximum at which you should change your oil,,,
    *Petron trekker CI-4 has no available Material data sheet or any product information sheet regarding the contents of the oil
    (personally i dont recommend this for personal vehicle use) there are a lot of better oils out there!!
    *Vic filters are not good filters if you intend to prolong your engine like it just rolled out of your casa... there are also a lot of alternatives filters out there which is 200% better than VIC, examples(baldwin/fleetguard/purolators/bosch)
    i suggest you read the REMOTE BYPASS OIL FILTRATION THREAD...
    http://tsikot.com/forums/engine-fuel...tration-79219/
    the only problem with those brands is availability.. most auto shops carry VIC or OEM filters.
    You can try surfing pinoysuperstore for your filters (bosch/Mobil 1). But oils, well there is obviously better alternatives than Petron.
    Jan 2008
    #23
    mukhang ayos to ah....
    Dec 2009
    #24
    baldwin/fleetguard and purolators have impressive micron rating for its filtering capabilities.. you can easily go 10,000kms...
    the best combination would be outstanding filters and oils with CI-4/SL rating of which must have at least a minimum of 10 TBN...the important thing is that the oil you will choose should have a posted product data sheet
    so that you know what you're paying for and what you're actually getting...
    definitely you will be able to SEE and FEEL the difference...
    Oct 2011
    #25
    un na nga... kailangan sadyain mo pa ung supplier or authorized dealers ng baldwin or fleetguard.
    Feb 2010
    #26
    mga bro, can you share the name's store & location of fleetgard and purolators?
    TIA po mag-share...
    Nov 2011
    #27
    Yung Kixx D1 alam ko pang gasoline engines.
    Kixx Turbo RV
    sir saan nakaka bili neto?
    Dec 2008
    #28
    Buhayin ko lang thread nato. Just curious about the company issued innova diesel that is religiously maintained by toyota shaw. The casa replaces the engine oil(toyota brand full synthetic) fully only every 10,000 kms. However, every * 5,000 kms interval, what they do is to replace the oil filter and top up only. And this is being done during the warranty period by the way. So it comes out na mura na din overall. Just sharing my actual experience.
    Jan 2014
    #29
    ako castrol oil o mobil..ayos din naman performance nya. di ganu naitim ang langis kapag updated sa pag change oil..good maintenance lang talaga kelangan.
    Dec 2008
    #30
    Quote Originally Posted by Red Advent 04 View Post
    Ano ang oil change interval mo bro.?
    Aug 2010
    #31
    using Delo 400 sa kia sportage crdi - every 5k kms oil change
    using Royal Purple 15w40 - every 10k kms oil change , every 5k kms OEM oil Filter change
    Oct 2011
    #32
    Quote Originally Posted by armscor40 View Post
    TIA po mag-share...
    Sir, sa pacers 5th caloocan meron pacers tapos sa kwik parts naman ung sa purolator.
    #33
    Update lang mga sir.
    Alin po mas maganda sa crdi engine. 2014 Accent Hatch po unit ko.
    Fully Synthetic - Change oil every 10k km (top up and change oil filter at 5k km)
    or
    Semi Synthetic - Change oil every 5k km?
    TIA
    Sep 2008
    #34
    using fully synthetic, semi synthetic, or conventional oil will not alter oil change intervals.
    #35
    Fully synthetic interval is 10k w/ top up of a liter & change oil filter at 5,000. At least that is the recommendation by the Casa. But if I were you, if your daily route takes you to high traffic areas & frequently gets stuck in traffic, do it every 5,000 (which means the better option is Semi synthetic). Reason being your mileage maybe low, but engine running time is long.
    #36
    Ako kasi, daily route is expressway & star tollway, around 750 km a week & 24 or 25 hours running time per full tank a week. May traffic, pero konti lang sa Alabang or Parañaque. Usually open highway or open free roadways.
    #37
    Sorry mejo OT,
    *bloowolf, db accent hatch din unit mo? Casa PMS ka pa rin ba o sa outside na? TIA
    #38
    Sorry mejo OT,
    #39
    Sorry double post, slow internet connection.
    #40
    Quote Originally Posted by andrewnathaniel View Post
    Sorry mejo OT,
    Yup, Hatch rin at Casa PMS
Interval for change oil CRDI engines
