Results 11 to 11 of 11
- Oct 2005
- 72
September 1st, 2006 02:35 PM #11Ciagar11, thanks sa advise mo.
appreciated!
actually napalitan na ng brand new servo motor .
- i believe nuong kinabit nila ito... tinangal nila iyon connection pole ng battery. But not sure how many minute bago i connect.
- do you think kung sakali hindi nasunod ito .... use less ang pagawa ng reset.
Ask ko lang are this the same application if ECU or ECI ang
now I'm planning to let them check the engine support and palinis iyong throttle.
remarks:
when I start up the engine
a. After startup RPM=Approx 1200
b. Sa "N" or "P" position at normal engine temp. RPM= Approx. 950
c. Sa "D" or "R" position RPM= Aprrox 650-550
If A/C ON
d. Sa "N" or "P" position Aircond "On" RPM =Approx 1000
e-Sa "R" or "D" 750 - 600 >>>lalo na pag napreno ka... nanginginig siya...
let me know if you still have idea to solve this..... for the time being I'll let them check the engine support... and trothle ..
thanks
Too many trucks in Marcos. Naguilan is too far coming from the south. So Kennon is a lot faster.
2023 Toyota Wigo
