guys question lang...my parking is at the basement 6 of a building, so malayo aakyatin ng car ko everyday after starting...eh medyo hindi pa mainit yun engine nun...is this bad for the car's engine? how long should i wait before i start going up...
In normal cases it's ok to start moving immediately once the oil pressure indicator lamp in your dash comes off and driving it slowly til it reaches normal engine temp. In your case of the car still climbing up is an added stress. Try warming up the engine for about two minutes then shift gear.
wag ka lang mag aircon habang paakyat ok na yan... unless wala sa tono makina mo di yan mahihirapan... usually di advisable mag rev over 4K pag cold pa makina pero under that walang problema yan...
i read an article before na dapat di mo i-idle lang yung car pag cold start... the best way to warm the engine up is to drive it na, pero wag yung hataw agad, a gradual press on the gas with low revs sa pag shift is the best way... pa-correct nalang po kung mali po nabasa ko
For gas engines, ok na siguro 30 seconds to 2 minutes kapag first start sa umaga. For diesels, warmups are more critical. Sa diesel ride ko, mga 10 minutes in the morning, but within the day, start and drive na.
mga sirs, I agree with ssaloon. that's what I'm getting on almost all article I encountered on the net. the longer warm-ups are now tell tales and not true anymore on todays vehicle. it is still best to drive at once but smoothly to warm-up the car kahit na siguro paakyat. remember that idling for a longer period of time doesn't do good at all.
pdc2, just what sir theveed and others said... start and drive smoothly with a/c off.
