Results 21 to 40 of 46
    Oct 2013
    #21
    Quote Originally Posted by khenma0928 View Post
    Sorry baligtad pala ung picture.. Eto na...
    ito best answer
    read the users manual...
    Oct 2015
    #22
    Watta kind of advice
    Quote Originally Posted by Manilablock View Post
    Regular PMS and remove clutter (which have weight), also drive earlier, while we are still sleeping so you will not waste fuel in traffic.
    #23
    Start>remove dust from exterior while waiting for the RPM to go down> drive.
    wouldn't that be wasting fuel, sir? your car could have moved some meters while waiting for the rpm to go down.
    even your manual says you should commence driving as soon as possible.
    May 2009
    #24
    1. Daily or weekly check (your choice) ng brake fluid, oil and coolant.
    2. Start engine. masama yung redondo agad pagkastart (ugali ng erpats ko na di ko na kaylanman mababago). check if warning lamps go off. kung hindi e di recheck vehicle.
    3. while idling, walk around ng sasakyan to check tires and their pressures. may kasama na ring silip sa ilalim kung may weeping or dripping leaks ng brake fluid pati na rin yung oils ng engine, trans, at diff.
    then eto na: walking > jogging > sprint
    pero usually #2 lang ang ginagawa ko. once a week lang yung #1 & #2.
    well maintained naman ang kabayo ko.
    #25
    You are not doing the environment any good by idling too long. 20 seconds would be enough to bring the oil up to circulate. Drive slowly till temp guage moves up a notch then drive normally. Idling the engine for a few minutes to warm up is soooo '70s. Checking for leaks while warming up? Check your garage floor instead. It should not have any oil/fluid stains aside from water condensation from the aircon. Checking your tires while warming the engine? You can do that anytime the car is parked & check the pressure if in doubt.
    May 2009
    #26
    kung ako ang pinapatamaan mo brader e basahin mong maigi yung post ko pag may time. ang sabi ko item #2 kadalasan ang ginagawa ko.
    tsaka isa pa 70s or 80s tech pa kasi yung sasakyan ko. pero i still minimize idling time. start-up at pagbukas ng gate. yung pag-antay lang naman ke misis ang nagpapahaba ng idling time ko (sinisi pa ang asawa).
    wala pa ni kalahating minuto para icheck kung may leak ang preno. anong ka-OA-han naman iyon? e kung sa may daan ka nawalan ng preno? ang flooring ay hindi magandang basehan dahil sa previous leaks or works na ginawa.
    if i may, regarding sa tire pressures, iba lang yung pagkakasulat ko (ngayon ko lang narealize). i do that once a week while the vehicle is parked. yung walk around ko lang is to check kung may sidewall cuts na diko namalayan from the previous drive.
    peace out brad. relax ka lang.
    #27
    Merely saying that long idling to warm up the engine is a useless habit that majority of pinoys do. I really don't know why it had to come up again. We all know that the engine will warm up eventually & be more fuel efficient when driven slowly in the first few minutes. You did mention that you do part of your routine, no matter how infrequent it may be. If you don't do it, then you would not have mentioned it. Merely mentioned also that leaks are first detected on the garage floor. Peace amigo.
    Jul 2015
    #28
    Since then every cold start I let the car run until the temperature needle reach its normal operating temperature.Pero one time I borrowed my cousins Nissan urvan(td27)when we are about to leave na I started the van then I wait for the temp needle to reach its operating temp but sad to say I wasted 30mins of my life waiting for that needle to reach its final place.wala nakakaasar walang permanenteng operating temp ang urvan :-D pag na traffic tataas ng konti hanggang half pag umaandar nasa cool lang. Haha
    #29
    Quote Originally Posted by ;2657012
    ...whypo..?
    why not just drive out once the engine starts running? i've been doing this for decades.. no manifestation of... whatever it is.
    i am curious... what are we trying to avoid...? what can possibly happen if one drives out even if the engine isn't warm enough yet, or when the rpm hasn't settled down yet??
    engine wear? i'd rather have engine wear because i went somewhere, than have engine wear while going nowhere, waiting for the engine to warm up.
    my thoughts only.
    #30
    Drive while sleeping??? kaya pala dumadami ang SUA.
    #31
    good advice.
    we all know what this means.
    tamad lang tayong gumising nang maaga..
    Oct 2015
    #32
    1. START
    2. PRAY THE ROSARY
    3. CHECK RPM. SURE MABABANA YUN.
    A true driver knows no brakes.
    Sep 2013
    #33
    Quote Originally Posted by blacksynovial View Post
    1. START
    2. PRAY THE ROSARY
    so it takes you at least 4 mins or more by the time you start driving???
    #34
    I drive immediately. I don't linger in the car anymore.
    Jan 2009
    #35
    Starting the engine is more often the first thing I do. So I just let it go through its motions while I settle in all my stuff, set the HU and Waze, wear my seatbelts, check all the mirrors, before backing out of the garage.
    The 'warm-up' period while I'm doing all the things above takes between 15-60 seconds.
    Jul 2014
    #36
    #37
    Inaantay ko lang mawala yung blue thermometer icon sa gauge, almost 1 min din yun. Then drive!
    Jul 2013
    #38
    Do not idle your car for so long in the parking lot.
    Jul 2015
    #39
    ...whypo..?
    my thoughts only.
    Pag labas po kase ng garage namin required kagad na mag high rev kase palabas palang puro pataas na medyo matarik tas salubungan kaya need to rev high minsan to overtake those crawling tricycles when going up.kaya before I left the house I make sure na normal operating temp na sila.
    Feb 2009
    #40
    Cars of decades ago had cooling system capacity between two to three gallons. Your car today has an average of a gallon. When fuel was cheap and people had little idea what air pollution does, engines were running cold and burning unnecessary fuel(cheap back then). Automotive engineers have been studying how to make cars fuel efficient by getting to normal operating temp in a short time and increasing miles per gallon and reducing the carbon dioxide footprint
How do you start your car's engine properly?
