You are not doing the environment any good by idling too long. 20 seconds would be enough to bring the oil up to circulate. Drive slowly till temp guage moves up a notch then drive normally. Idling the engine for a few minutes to warm up is soooo '70s. Checking for leaks while warming up? Check your garage floor instead. It should not have any oil/fluid stains aside from water condensation from the aircon. Checking your tires while warming the engine? You can do that anytime the car is parked & check the pressure if in doubt.
kung ako ang pinapatamaan mo brader e basahin mong maigi yung post ko pag may time. ang sabi ko item #2 kadalasan ang ginagawa ko.
tsaka isa pa 70s or 80s tech pa kasi yung sasakyan ko. pero i still minimize idling time. start-up at pagbukas ng gate. yung pag-antay lang naman ke misis ang nagpapahaba ng idling time ko (sinisi pa ang asawa).
wala pa ni kalahating minuto para icheck kung may leak ang preno. anong ka-OA-han naman iyon? e kung sa may daan ka nawalan ng preno? ang flooring ay hindi magandang basehan dahil sa previous leaks or works na ginawa.
if i may, regarding sa tire pressures, iba lang yung pagkakasulat ko (ngayon ko lang narealize). i do that once a week while the vehicle is parked. yung walk around ko lang is to check kung may sidewall cuts na diko namalayan from the previous drive.
peace out brad. relax ka lang.
