Results 1 to 10 of 21
- Oct 2005
- 72
October 18th, 2005 05:42 PM #1Guy.... might help me to give some ideas ...
My ride having a problem ... about the idling goes up and down iyong indicator
niya once naka on ang a/c .. but whent a/c off normal idling niya around 950rpm.
do you think auxillary fan also a factor that cause of this aside from servo kit.
please help me
October 18th, 2005 06:02 PM #2
pa-check mo muna yung servo ... also you might want to check your belts ;-)
- Oct 2005
- 72
October 18th, 2005 07:15 PM #3I already had replace the belt with new one last 2 months and the servo ...
- Oct 2005
- 72
October 18th, 2005 07:18 PM #4the reason why nang nag paayos ako and nagkarga ng freon/A/C ay nag flactuate ang idling up and down....
October 19th, 2005 12:28 AM #5
Pa check mu fuel system. Wag servo lang. Ang GTi namin dati pinalitan ng servo un pala e hindi servo kundi ung mismong kinakabitan ng servo. Sakit ng Lancer yan.
- Oct 2005
- 72
October 19th, 2005 07:48 AM #6kokey, after your fuel system has been check ... ok na iyong GTI mo.......?
matagal checkin ang fuel system ..... is seems strange kasi... they always tell servo...
as far a i know servo ay hindi ganun kadali diba...? any factor that possible cause
of this flactuating the idling.
appreciated your advise.
October 19th, 2005 08:47 AM #7
Last time I experienced fluctuating idle was when the so-called aircon tech overcharged my system.
Have your engine checked. It might just be a loose wire or hose somewhere. The servo's gears can be replaced if needed but sometimes just cleaning it does wonders. Click on the link on my signature and look for the "Recommended Shops and Mechanics" thread.
- Oct 2005
- 72
October 19th, 2005 09:14 AM #8thanks bro..... actually I already replace the servo..... and done tune up chang oil...
October 19th, 2005 09:59 AM #9
No prob bro. Ok na idling mo? Kano pala kuha mo sa servo? Surplus o brand new?
- Oct 2005
- 72
October 19th, 2005 01:13 PM #10bro, iyong nga eh... surplus lang iyon binili ko,,, and 3 months na ginamit . tapus
pinaayos ko a/c last week lang .. nang nakargahan ng freon.... a day after... nagkaproblema iyong idling.... then pinacheck ko ang sabi naman servo daw...
any suggestion... kasi mahal ng servo.... diba... kuha ko sa surplus sa imus 5K.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
