Results 1 to 10 of 26
- Oct 2016
- 21
November 9th, 2016 03:53 PM #1Paps - okay lang ba na diesel engine oil ang nailagay sa petrol/gasoline engine ko nung nag pa tuneup ako? 15w40 ang oil ang nilagay sa 2.0L engine ko? thanks sa mga sasagot
November 9th, 2016 04:00 PM #2
Depende sa oil na nilagay mo.
At depende din sa kotse mo.
Ano ba nilagay mo, at bakit?
November 9th, 2016 04:02 PM #3
Depends on the oil. Some oils can be used in both gas and Diesel engines. They would have an API mark like SN/CF (SN if used on gas, CF if used on a Diesel). But if the oil is spec'd with API CF, API CH, API CI, etc., they're exclusively designed for Diesel engines.
- Oct 2016
- 21
November 9th, 2016 05:03 PM #4
[QUOTE=ronki;2784207]Depende sa oil na nilagay mo.
Mitasu brand sir 15w40 - sa 2.0 honda CRV ko. kasama sya sa tuneup package yung oil sir. worry ko lang upon checking the grade of the oil- ang sabi nila it for diesel engine.
Kaya ang worry ko ngayon sir- hindi nya kaya ma damage ang engine? thankd
- Jun 2005
- 3,774
November 9th, 2016 05:15 PM #5You need to know what type of mitasu oil was used. Yung iba may gasoline equivaleny so no problem yan.
I've been using diesel oil in gasoline engines for about 4 years now. DELO pa nga. Ayus naman
- Oct 2013
- 2,537
November 9th, 2016 05:16 PM #6
November 9th, 2016 05:42 PM #7
ang pagkakaintindi ko sa post ni ts e siguro yung mekanikong nakausap nya e ang line of thinking ay kung SAE 15W40 yung langis e pang diesel na. not knowing na may API ratings pa na kelangan malaman. kumbaga sa viscosity lang nagbase.
tapos considering honda yung sasakyan nya...di bat sabi nila e sensitibo ang mga honda sa fluids. ewan.
- Oct 2016
- 21
- Apr 2012
- 3,469
November 9th, 2016 09:41 PM #9
- Jun 2005
- 3,774
November 9th, 2016 11:39 PM #10
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
