Quote Originally Posted by 7138 View Post
check mo sir fuel filter mo, napalitan mo na ba? according to your post, may gasolina pa sa carb bago mo istart, so may naakyat pa gasolina sa carb mo bago mo patayin the day before, then eto na, the next day, you try to start for the first time, nagstart! kasi, may nakaimbak pang gasoline sa reserve eh, eh nagkataon naubos na, namatay yung engine, ibig sabihin, kulang na yung umaakyat na gasolina, pwede kayang hirap ng itulak ng fuel pump mo kasi barado na fuel filter mo? or, mahina na fuel pump mo and hindi na sya makapwersa initally ng gasoline to your carb. check mo na muna sir fuel filter mo.
Goodluck!
Sir, I already replaced my fuel filter and battery terminals the other day. Nung gagamitin ko na yung auto this morning, the same problem still exists. Umistart but after a few minutes bumababa ang rpm hanggang sa tuluyang namatay. Naghard starting na, ayaw ng tumuloy, so chineck ko ang carb kung tuyo pero may gasolina naman.
Just wanna make sure kung carb nga po ang problema or may iba pang pwede maging cause. May kalayuan po kasi ang cavite sa kamuning, sayang ang byahe kung hinde naman pala carb ang dahilan. Kung may carb expert lang sana sa cavite or kahit around las pinas and alabang na anytime pwede puntahan.
Any inputs will be very much appreciated. Thanks
