Results 11 to 20 of 20
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 14th, 2013 04:36 PM #12
Sa mga nabasa ko na dito, ang Caltex DGU ay safe din gamitin sa gasoline engines dahil sa rating na API CI-4/SL, mababa ang ZDDP at Phosporous content kaya won't harm the catalytic converter. I also read that this motor oil have high detergency additives that removes engine sludge slowly and suspend them sa oil to be trapped sa filter, kung gaano katagal cleanse the engine sludge, siguro, depende na sa amount present.
September 14th, 2013 11:58 PM #13
Volatility is inversely proportional to ZDDP content.
Meaning, the lesser the ZDDP content, the more likely na mag change to gas state ang motor oil and ma-coat ng motor oil ang catalytic converter.
September 15th, 2013 07:49 AM #14
Hindi ata volatile ang oil sa normal na takbo ng makina sa 60 centigrade. Hindi mageevaporate ang lube oil base stock. Ang gamit sa automotive engine oil ay halimbawa 500 SN may flash point na 237 centigrade.
AP/E SN 500.
Pag umabot ng 200 centigrade ang engine oil temperature mo, magdasal ka na men.
Ang ZDPP anti-wear lang ito, ika nga e pampadulas lang ng bakal.
https://en.wikipedia.org/wiki/Zinc_dithiophosphate
- Feb 2003
- 1,038
September 15th, 2013 09:06 AM #15ZDPP ia one known poison of the catalyt in a catalytic converter, oil mist can somehow be carried over sa gas exhaust via the valve seals..WALA namang perfect sealing engine..thru that mapupunta yung ZDPP. my stance is mas priority ko engine parts Kesha sa catcon. And not instantaneously naman masira ang catcon..it's expensive but dami mabilihan surplus nito.
September 15th, 2013 09:26 AM #16
September 15th, 2013 12:42 PM #17
Sir Jiggs answered your comment. I hope you'll stop praying.
Sumasama din sa combustion chamber ang oil. What determines if it will become gas is the temperature and PRESSURE inside the chamber. (You can boil water at zero degrees celsius) Once it changes to gas state, the hydrocarbon engine oil will ignite. Engine oils are hydrocarbons with additives like zinc, zinc will still be zinc and will not participate with the fuel-oil-oxygen combustion. It will be in a gaseous state though and will pass thru the cat con.
That's what they (API and car manufacturers) say.
Having an API license is expensive, but if you do have it, car manufacturers will promote your oil.
It's all about money.
- Sep 2013
- 630
September 15th, 2013 01:51 PM #18nivraarvin, jiggs,
Ano level ng zddp ang safe pag may catalytic converter?
Ano oil maadvice nyo sa subaru brz at civic fd. Dalawa choice ko delo 400 or zic a?
September 15th, 2013 01:55 PM #19
September 15th, 2013 06:57 PM #20
ZDDP content of less than 1200 ppm is safe for cat con of gasoline engines, that's API CI-4/SL grade, as per previous posts dito
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
