Results 1 to 10 of 35
June 29th, 2005 01:21 AM #1
Mga bro,
Balak ko kasi mag-palit ng fuel filter saan ba banda' matatagpuan yon? Pasensya na kelangan ko kasing matuto ng konti sa masters natin dyan
June 29th, 2005 01:51 AM #2
it will be better if you will also post your car/truck for specifics...=)
July 1st, 2005 07:56 PM #4
Originally Posted by antonmace
It was a an surplus engine i think 80's model pa ito >ISUZU GEMINI 4FB1.naka mount sa assembled wrangler.
July 3rd, 2005 09:07 PM #5
Sundan mo lang ang fuel line either from the tank or from the injection pump. Check mo sa gallery ko kung may picture ng fuel filter. Usually canister-type siya with a hand pump on top.
Meron ding in-line (nasa fuel line mismo) na fuel filter. usually cylindrical ito and semi-transparent.
Pero ang mahirap sa assembled vehicle, baka hindi ito ikinabit ng assembler mo. Goodluck searching.
July 4th, 2005 04:53 PM #6
how long po ba bago dapat palitan yung fuel filter for diesel engine (2B landcruiser)?
thanks.
July 4th, 2005 05:02 PM #7
Originally Posted by mcbry
depends on the quality of diesel you use. i also have a surplus engine sa minicruiser ko and I usually change the fuel filter once a year pero if i had money i change it every 6 months kasabay ng palit ng oil, oil filter at air filter para swabe
July 4th, 2005 05:06 PM #8
FYI lang. I just replaced Fuel Filter of my FieldMaster last Saturday as I'm having difficulty getting it started in the morning. Big improvement on cold start response, its now more responsive when accelerating. For my ride, it is recommended to be replaced every 10K km.
July 5th, 2005 02:35 AM #9
Originally Posted by OTEP
"Usually canister-type siya with a hand pump on top." Ito po ba yung handpump na pag-natutuyuan ng diesel e dito binobomba para lumabas yung hangin
July 5th, 2005 09:29 AM #10
Another question... what are the feedbacks on using OEM vs. replacement canister filters? Any recommended brand? My dilemma now is i want to change every 10,000m vs. every 20,000km that is recommended by the manual but the Frontier uses two fuel filters and it's quite pricey for the OEM (sets me back around 4K).
What then is more adviseable?
1. Status Quo: Change every 20,000km and stick to the OEM fuel filter
2. Change every 10,000km but employ a replacement brand.
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
