no ba bad effects pag hindi ka nagpapalit ng fuel filter? no ba ang symptoms na kelangan ka na magpalit?may mararamdaman ka ba agad na significant effect sa takbo kung magpalit ka?
pigil ang takbo, lalo na sa highway. minsan pag binitiwan mo ng konti ang gas, biglang bibilis.
pag malala na, kahit idling rough ang takbo, and rpm mo, gagalaw galaw.
additional lang po. may idea ba kayo magkano fuel filter hatch na civic eg ph12?.ok lang ba sa mga gas station mag papalit nito?
yhap, okay lang sa gas station magpapalit nyan, no idea lang how much is it. generally, mura lang ang fuel filter. less than P150
ngek ganun lang ba kamura un.hehe.. kasi nabassa ko sa isang thread dito may nag papalit ng fuel filter ng accord sa casa fuel filter na original pa lang 1500 na.o baka mahal lang talaga ung sa accord?
ginoogle ko ung fuel filter change. parang an dali lang i DIY kung may lifter hehe. un lang ung maliit na lat
Palitan mo na.. mura lang naman ang fuel filter. Considering the peace of mind that you can have with a new fuel filter.
I change my fuel filter every change oil.
yup ill take that advise. standard oil change oil filter lang palit. kakachange oil ko lang pero pa change fuel filter ko na next week pag nag ka time tutal mura lang naman pala e..
Kung plastic filter yun no prob, pero kung yung metal-type filter not recommended, masyadong mahal yun para palitan ng ganung short intervals, probably every 2 years or so, depende sa usage, condition ng oto.![]()
Just clarifying it to avoid more confusion on some tsikoteers!![]()
You should change your fuel filter according to your manual's recommendation. But if you don't have it, it would be safe to change it every 10,000-15,000 kms.
HTH![]()
it depends on your vehicle too.
for example, the fuel filter of my rav4 only needs replacement every 100K km.
very simple lang pag change nyan actually, thought your not the diy type.
2 hose lang meron yan and just follow the route to your new filter
only the plastic filters are that cheap. the metal ones tend to be a little more expensive than that.
Yung fuel filter ng Accord, mahirap palitan. Tatanggalin pa yung intake manifold, to create room to access it. Actually, tinanggihan ako ng mga mekaniko sa Shell Pook Ligaya, hindi raw nila kaya after visually inspecting my ride, and even putting it on a lift. Civic lang daw yung kaya nila. Eventually, kay Speedyfix ko dinala
Yung Sentra ko, ako lang ang nagpapalit, madali naman kasi
crosswind vic fuel filter costs less than P200 kaya kahit every 5K kms
okay lang. based on owner's manual it should be at 20K intervals.
kakabili ko lang ng fuel filter and air filter for the Starex and the Corolla '94.
Starex Fuel Filter : 600
Starex Air Filter : 250
Corolla Fuel Filter : 700
Corolla Air Filter : 350
Tried top DIY the fuel filter of the Corolla, ang hirap abotin at tanggalin ng screws. I stopped and will just have it done at Goodyear Servitek siguro. Hassles eh.
