Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    no ba bad effects pag hindi ka nagpapalit ng fuel filter? no ba ang symptoms na kelangan ka na magpalit?may mararamdaman ka ba agad na significant effect sa takbo kung magpalit ka?
    May 2005
    pigil ang takbo, lalo na sa highway. minsan pag binitiwan mo ng konti ang gas, biglang bibilis.
    pag malala na, kahit idling rough ang takbo, and rpm mo, gagalaw galaw.
    additional lang po. may idea ba kayo magkano fuel filter hatch na civic eg ph12?.ok lang ba sa mga gas station mag papalit nito?
    May 2005
    yhap, okay lang sa gas station magpapalit nyan, no idea lang how much is it. generally, mura lang ang fuel filter. less than P150
    ngek ganun lang ba kamura un.hehe.. kasi nabassa ko sa isang thread dito may nag papalit ng fuel filter ng accord sa casa fuel filter na original pa lang 1500 na.o baka mahal lang talaga ung sa accord?
    Jun 2005
    Quote Originally Posted by gowthead View Post
    Kung sa casa mahal talaga ang presyo at ang presyo ng honda parts ay talagang mahal.
    ginoogle ko ung fuel filter change. parang an dali lang i DIY kung may lifter hehe. un lang ung maliit na lat
    Aug 2004
    Palitan mo na.. mura lang naman ang fuel filter. Considering the peace of mind that you can have with a new fuel filter.
    I change my fuel filter every change oil.
    yup ill take that advise. standard oil change oil filter lang palit. kakachange oil ko lang pero pa change fuel filter ko na next week pag nag ka time tutal mura lang naman pala e..
    Quote Originally Posted by hyperthread View Post
    Kung plastic filter yun no prob, pero kung yung metal-type filter not recommended, masyadong mahal yun para palitan ng ganung short intervals, probably every 2 years or so, depende sa usage, condition ng oto.
    Just clarifying it to avoid more confusion on some tsikoteers!
    May 2004
    You should change your fuel filter according to your manual's recommendation. But if you don't have it, it would be safe to change it every 10,000-15,000 kms.
    HTH
    it depends on your vehicle too.
    for example, the fuel filter of my rav4 only needs replacement every 100K km.
    May 2005
    very simple lang pag change nyan actually, thought your not the diy type.
    2 hose lang meron yan and just follow the route to your new filter
    Nov 2003
    only the plastic filters are that cheap. the metal ones tend to be a little more expensive than that.
    May 2004
    Quote Originally Posted by mazdamazda View Post
    +1 on that sir. Pero kung replacement lang ang gamit, safe na yung every 10K km.
    Sep 2006
    Quote Originally Posted by Asus700 View Post
    tanong lang po...paano naman pag kunwari naka third o fourth gear ka tapos pag binigla mong inapakan ang gas eh biglang nag he hesitate yung takbo na parang naubusan ng hangin..is this in any way related to the fuel filter? Or normal lang? thanks
    Sep 2004
    Yung fuel filter ng Accord, mahirap palitan. Tatanggalin pa yung intake manifold, to create room to access it. Actually, tinanggihan ako ng mga mekaniko sa Shell Pook Ligaya, hindi raw nila kaya after visually inspecting my ride, and even putting it on a lift. Civic lang daw yung kaya nila. Eventually, kay Speedyfix ko dinala
    Yung Sentra ko, ako lang ang nagpapalit, madali naman kasi
    crosswind vic fuel filter costs less than P200 kaya kahit every 5K kms
    okay lang. based on owner's manual it should be at 20K intervals.
    May 2005
    Quote Originally Posted by Hanren View Post
    you mean nabibilaukan... ang dami pwede panggalingan nyan eh.
    pwedeng fuel filter or sa fuel system, pwedeng sa carb kung carb ang sasakyan mo, pwedeng sa sparks related sa electrical.
    pwedeng incorrect timing.
    Oct 2004
    kakabili ko lang ng fuel filter and air filter for the Starex and the Corolla '94.
    Starex Fuel Filter : 600
    Starex Air Filter : 250
    Corolla Fuel Filter : 700
    Corolla Air Filter : 350
    Tried top DIY the fuel filter of the Corolla, ang hirap abotin at tanggalin ng screws. I stopped and will just have it done at Goodyear Servitek siguro. Hassles eh.
fuel filter change
