Sir,
kung anong timing belt po ang nakalagay sa, Toyota Revo 2003 model Engine 7k, Gasoline..
Timing belt o Timing Chain ano po b? Anyone can help me...???
Sir,
SA TOYOTA 5k Engine ko timing chain ang nakalagay. Mas prefer ko timing chain kesa belt . Iingay lang pag early start mo sa umaga pag akyat na langis wala na at hindi ka natatakot na maputulan . Ang belt naman may certain mileage na kailangan palitan delikado doon sa hindi marunong sa makina . Pag naputol maraming masisira sa makina at malaking gastos.
7k is timing chain. may fx kami na 7k engine. 100% sure yan bro... bakit, magpapalit ka na?
speaking of timing chain, when is the recommended change interval of the tensioner?
gus2 ko sanang i-check ung timing chain ko... san ba banda nkalagay yon???
anyone can help...??
bat kaya yung sa akin, pinalitan timing chain, after a week medyo maingay na siya pag mainit na engine, paka-start naman tahimik lang siya.
Mula 3K-H nung 70's, 4K nung 80's, 5K ng liteace, hanggang 7K ng FX, puro timing chain lahat. iisa lang ang block nila![]()
Ask ko lang mga tsikot...Is revo vx200 1RZ-E engine is timing belt or chain?thanks..
The decision to replace is dictated by factors such as noise, and bad ignition timing. Usually you change the chains, the gears, tensioners, guides, etc. based on noise.
Changing any of the chains without changing the gears/
sprockets lead to faster chain wear for obvious reasons.
Re-using the old tensioners and guides simply does not make sense if one wants to minimize noise.
