Results 11 to 17 of 17
June 24th, 2008 02:51 PM #11
^^^^^^The cure is to basically warm up your engine and run it to the limits of each gear, in every gear, for a good while. para exercised siya
- Jan 2008
- 152
July 17th, 2008 01:25 PM #12may service na ganyan. de-carbonizing yata tawag dun.
nag-DIY lang ako. i just used water. fed it thru the pipe, tinakpan ng basahan (dapat may nakahawak), rev ng malakas, bigla mong alisin yun basahan. the water & carbon was blasted up to 20 ft. did this 3 times yata in one sitting.
so far, no problems with the muffler.
depende rin siguro sa type of muffler. mayroon kasing may glass or fiberglass sa loob. yung iba may foam yata or some kind of filter material.
but i'm not suggesting you do this procedure... baka sisihin nyo pa ako!
July 17th, 2008 01:54 PM #13
July 18th, 2008 11:32 PM #14
I'm having weekly problems with our diesel ride.
my pops drive it conservatively, gas pedal never reach more than 50%. but when I ride it sometime for once a week. then makes a quick high rev in overtaking, it puffs heavyweight smoke. nakakahiya...but the second time and the rest of the day, smoke is barely visible kahit todo na ang tapak.
flushing muffler weekly is also wasting fuel.
ano kaya ang cheaper solusyon dyan?
I don't think even a 1300 watts vacuum can suck.
some innova also has this kind of trouble.
July 19th, 2008 01:35 PM #15
Just stab on the go pedal when somebody is tailgating you parang pusit
Ganyan talaga ang diesel kapag hindi naitakbo nang sustained high speed for a while. Place some fast paced music on the stereo while your dad is driving, it may work to that effect. Kung hindi, you can adjust the throttle linkages a bit to compensate
July 19th, 2008 05:43 PM #16
I'm telling him to go hard for some time nalang. don't want to change my settings na. I remember when I drove it again first time from more than a month, the smoke is so bad, parang bumigay yung makina sa overtake. kakahiya talaga.
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 20th, 2008 11:07 AM #17no need na to do this imo. the water will just get stuck inside the muffler and degrade it even faster.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
