Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Dec 2019
    Just bought a copycat of this provent 200 catch can around 1.8k.
    Looking at feedback if its true that these copy provent catch cans are “good enough” and “safe enough” to use.
    Did alot of research on OCCs and came across this article that states that these copycat provents did as well as other non-provent big brand oil catch cans.
    UNSEALED 4X4 ISSUE 057
    Car is a 2020 fortuner 6,000 kms.
    Jan 2008
    How much and where did you buy? Online? Looks ok...im just worried that the element might get clogged restricting the blowby gas
    Apr 2012
    ^ ok naman din yan, just ensure that the rubber hose is the right size so as not to restrict the flow of blow by gas. the filter medium get easily soaked too with oil depending on the oil coming with the blow by gas and may get clogged so you need to replace it often. ask the seller if meron siya ng filter with steel mesh medium so you can just wash it with degreaser and re-use.
    btw, i removed and stopped using it in my montero about 2-3yrs ago ang replaced it instead with a generic occ. i had traces of oil leaking in the turbo area which i think due to the provent occ and nawala na ng mapalitan.
    Dec 2019
    Found a supplier sa fb benta nga P1,800. Hirap kasi if from shipping overseas matagal
    True was thinking about that nga eh. Gagana kaya pa rin if tangalin ung filter element? Hahahaha
    Dec 2019
    Yes was looking into proper hosing to prevent any backpressure from ruining the engine. The diameter of the inlets are 25mm so its big, bigger than the hosing ata ng fortuner.
    Will also look into the mesh filter insert cuz i dont want to keep buying din hehe.
    Nagleak kaya sa turbo bc of backpressure? New monty ba yan? U replaced it with the regular greddy aluminum ones? Ok ba?
    Apr 2012
    Quote Originally Posted by hdj80 View Post
    not sure if may back pressure pero may traces ng oil leak after few months na naikabit. mga mahigit 2yrs old na unit ko ng maikabit, posted the photo here in older thread. yes, yung generic oil cans, nawala yung trace ng oil after that. now, nasa storage lang yung provent copy ko with steel mesh type filter element. i can sell sa interested[emoji28]
    Dec 2019
    Hmm sounds like pressure buildup nga boss. Kasi since you switched to the new generic cans, na wala filtration empty can, di na nagkabuildup.
    Did it do damage to the seals of the engine or turbo or wala naman leak lang?
    Apr 2012
    no damage naman, may trace ng leak lang before. now, hardly noticeable na yung blow by oil, i haven't drain the OCC for quite awhile na, wala din naman laman. kahit dun sa outlet hose ng occ na nakasalpak sa air intake line prior to turbo compressor side, barely na my trace ng oil. i checked also the outlet of the intercooler nung nagpalit ng timing belt at ipinalinis ko up to intake manifold, malinis at walang oil gunk deposits.
    Mahal ng 1,800. I got two for P815 each only via Lazada. Ships from overseas but item arrived in exactly one week. From pictures it looks identical to what hdj80 got. Planning to use with Pajero and Everest.
    Dec 2019
    Hehehe yes I saw those in Lazada as well. Tempted to order but my last overseas order took 2 weeks to arrive. Decided to just buy the more expensive one here kasi instant.
    Good to hear tho it arrived in one week. Takot lang ako madedelay shipment from overseas bc of ncov problems
    Dec 2019
    Thanks for the feedback! Will just monitor din for leaks in case magka prob tong OCC na to hehe
    Punta ka sa website ng Berrima Diesel Australia and you view their video on China knock off.
    Jan 2008
    Remember that the OCC is intended to "catch" the oil from the air mist of blowby gas.. its not intended as a full time oil in air separator... the objective is to minimize the oil mist without sacrificing air flow
    Aug 2017
    These work well too. I installed in all of my grab cars sunce 2016
    Jan 2008
    Quote Originally Posted by SidCoronel View Post
    Much better yan... to trap oil mist.. mine i placed steel wire mesh to trap the oil mist
    Actually yung steel mesh yung primary criticism ni Berrima Diesel Australia about some of the Provent copies. Hindi daw naseseparate ng maayos yung oil mist from the air compared to a proper filter.
    Yung leaks madali lang naman ayusin by using additional rubber gaskets or gasket maker, pero with the steel type filter it won't work as intended.
    Feb 2003
    since big savings na, buy an orig filter element na lang....for sure your knock offs will be performing same as the orig na.
    Quote Originally Posted by Jiggs View Post
    The original coalescent filter is more than 2X the price of the complete knock off kit and my not fit 100%,
    Sir, where to buy the orig filter of Provent 200 ? I have the orig Provent 200 oil catch can...
    One of the comments in Lazada says that the fake Provent 200 filter does not fit the orig Provent 200 oil catch can.....
    https://www.lazada.com.ph/products/s...TLEku&search=1
    Feb 2003
    Not sure if meron pa sila..pinabili ko sken sa friend ko frm Cebu..Totus Tuus Trading Cebu based..but >3years ago na yun...
Feedback on copy provent 200 oil catch cans?
