^ ok naman din yan, just ensure that the rubber hose is the right size so as not to restrict the flow of blow by gas. the filter medium get easily soaked too with oil depending on the oil coming with the blow by gas and may get clogged so you need to replace it often. ask the seller if meron siya ng filter with steel mesh medium so you can just wash it with degreaser and re-use.
btw, i removed and stopped using it in my montero about 2-3yrs ago ang replaced it instead with a generic occ. i had traces of oil leaking in the turbo area which i think due to the provent occ and nawala na ng mapalitan.
Yes was looking into proper hosing to prevent any backpressure from ruining the engine. The diameter of the inlets are 25mm so its big, bigger than the hosing ata ng fortuner.
Will also look into the mesh filter insert cuz i dont want to keep buying din hehe.
Nagleak kaya sa turbo bc of backpressure? New monty ba yan? U replaced it with the regular greddy aluminum ones? Ok ba?
