Results 11 to 18 of 18
October 14th, 2006 04:28 PM #11
ganun pala yun, that also happened with my 626 AT. sa morning lang mahirap mag start. pag mainit na one click na lang.
Toyota is my choice
- Aug 2005
- 2,063
- Oct 2005
- 74
October 15th, 2006 08:30 AM #13Sir, sa palagay ko ipa check mo yang fuel pump baka defective na kasi sabi mo nag shut off ang yng engine mo after 5 second na start.T saka sabi mo inaapakan mo pa ang yng gas pedal para maka sustain yng engine during start.Cge Good luck.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2006
- 70
October 15th, 2006 09:16 PM #15I agree with speedyfix. Its not fuel pump. But it has to do with fuel supply to the engine. Filter as Yebo said could be the culprit.
- Aug 2006
- 70
October 15th, 2006 09:21 PM #16
Zombie
- Aug 2006
- 728
- Feb 2004
- 6
October 16th, 2006 09:33 AM #18Thank you sirs! Really appreciate all your inputs. Will go to a mechanic later and let you know what happens hopefully the fuel filter replacement and efi cleaning will do the trick.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
