Results 1 to 18 of 18
    Jul 2006
    Maybe the function that increases idle on a cold start is defective. You mention that if it's warm, there's no problem. Definitely electrical.
    Oct 2005
    ganun pala yun, that also happened with my 626 AT. sa morning lang mahirap mag start. pag mainit na one click na lang.
    Aug 2005
    proper tune up..
    Oct 2005
    Sir, sa palagay ko ipa check mo yang fuel pump baka defective na kasi sabi mo nag shut off ang yng engine mo after 5 second na start.T saka sabi mo inaapakan mo pa ang yng gas pedal para maka sustain yng engine during start.Cge Good luck.
    Nov 2003
    it's not the pump. kung pump yan di ka aandar in the first place.
    Aug 2006
    I agree with speedyfix. Its not fuel pump. But it has to do with fuel supply to the engine. Filter as Yebo said could be the culprit.
    Aug 2006
    Quote Originally Posted by speedyfix View Post
    I agree with speedyfix. Filter could be it as yebo said. You might want to have your EFI cleaned too. The problem basically has to do with fuel supply to the ignation chamber IMO.
    Aug 2006
    have your fuel lines and filter checked, and have your efi scanned.
    Feb 2004
    Thank you sirs! Really appreciate all your inputs. Will go to a mechanic later and let you know what happens hopefully the fuel filter replacement and efi cleaning will do the trick.
Engine is starting but it dies down after 5 seconds...
