Results 11 to 18 of 18
October 14th, 2006 04:28 PM #11
ganun pala yun, that also happened with my 626 AT. sa morning lang mahirap mag start. pag mainit na one click na lang.
Toyota is my choice
- Aug 2005
- 2,063
- Oct 2005
- 74
October 15th, 2006 08:30 AM #13Sir, sa palagay ko ipa check mo yang fuel pump baka defective na kasi sabi mo nag shut off ang yng engine mo after 5 second na start.T saka sabi mo inaapakan mo pa ang yng gas pedal para maka sustain yng engine during start.Cge Good luck.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2006
- 70
October 15th, 2006 09:16 PM #15I agree with speedyfix. Its not fuel pump. But it has to do with fuel supply to the engine. Filter as Yebo said could be the culprit.
- Aug 2006
- 70
October 15th, 2006 09:21 PM #16
Zombie
- Aug 2006
- 728
- Feb 2004
- 6
October 16th, 2006 09:33 AM #18Thank you sirs! Really appreciate all your inputs. Will go to a mechanic later and let you know what happens hopefully the fuel filter replacement and efi cleaning will do the trick.
Suzuki JIMNY [merged threads]
