Results 1 to 6 of 6
- 441
October 12th, 2003 11:36 PM #1is there such thing?aside from changing its oils,what else do you have to check or change in a diesel engine?unlike sa gas fed engines that you have to change spark plugs,check its timing etc.baka kce my na ooverlook ako eh.
October 12th, 2003 11:43 PM #2
Change fuel filter every 20k and air filter every 10k. I guess the rest is just the saame with gas fed like Power steering, radiator, brake/clutch fluid.
IMO lang
October 12th, 2003 11:43 PM #3
change oil/fuel/air filter. adjust valve clearance. injection pump calibration but this is on a need to basis.
4x4ph.com
- 695
October 13th, 2003 10:09 AM #4also, if you really want to make sure, you can call Central Diesel Clinic at 4113711 to 13
- 441
October 13th, 2003 12:25 PM #5ayt,thanks guys,pero mas easier and cheaper e maintain talaga ang diesel right compared to gas fed engines?
October 13th, 2003 05:27 PM #6Originally posted by nikko m
screw the chinese mini EVs (wuling, ice cream, etc). i'll be waiting for this VF3
Vinfast Philippines
