Results 1 to 6 of 6
    is there such thing?aside from changing its oils,what else do you have to check or change in a diesel engine?unlike sa gas fed engines that you have to change spark plugs,check its timing etc.baka kce my na ooverlook ako eh.
    Change fuel filter every 20k and air filter every 10k. I guess the rest is just the saame with gas fed like Power steering, radiator, brake/clutch fluid.
    IMO lang
    change oil/fuel/air filter. adjust valve clearance. injection pump calibration but this is on a need to basis.
    also, if you really want to make sure, you can call Central Diesel Clinic at 4113711 to 13
    ayt,thanks guys,pero mas easier and cheaper e maintain talaga ang diesel right compared to gas fed engines?
    theoretically hehehehe
diesel tune-up?
