Results 1 to 10 of 21
- May 2007
- 10
January 3rd, 2008 02:23 PM #1Good day.. Ask ko lang po kung ano problem ng auto ko. Corrolla GLI po sya 93 model. Nagbabawas po kasi ng langis and pag matagal na sya tumatakbo medyo mausok na lalo pag mag change gear na. Wala naman sya tagas ng langis sa grahe nmin kaya nagta2ka ako kung bakit lagi kulang langis nya. Eh office house lang takbo nya. Almost one hour lang per day tinatakbo nya.. Need some advise para pagpunta ko sa shop im sure na di huhulaan kung ano sira.. thanks..
January 3rd, 2008 05:31 PM #2
1. please check kung may langis sa radiator mo. if there is oil in the water may leak na cylinder head mo kailangan mo ng top overhauling.
2. if no. 1 is ok pwedeng kumakain na ng langis ang piston and that explains the black smoke. medyo malaki ang problem if this is the case dapat na iparebore yung engine block or kung nagtitipid pa pwede ipadukot yung piston na may leak na.
January 3rd, 2008 05:57 PM #3
hey bro, mukhang may blowby na makina mo. since na nag babawas ng langis ang makina, pero wala namang tulo. so in this case, you probably have a very worn out Piston Rings and Valve Stem Seals and Guides. which are all internal engine problems.
anywayz, kung dadalhin mo sa shop yung kotse mo. ipa compression test mo muna ang makina, then post mo dito ang results.
aite, peace.
- Dec 2007
- 40
January 3rd, 2008 06:39 PM #4Why compression test?? Magbabayad ka lang..
for overhauling na yan....
sure
- Dec 2007
- 40
January 3rd, 2008 06:39 PM #5Why compression test?? Magbabayad ka lang..
sure ka
- Dec 2007
- 40
January 3rd, 2008 06:39 PM #6Why compression test?? Magbabayad ka lang..
sure ka na
- Dec 2007
- 40
January 3rd, 2008 06:40 PM #7Why compression test?? Magbabayad ka lang..
January 3rd, 2008 08:58 PM #8
sonjeffrey ok na naiitindihan naman namin promise!! Peace bro
mkeculit,
Mileage? Malangis ba tambucho? Smell of exhaust?
- Dec 2007
- 40
January 4th, 2008 07:09 PM #10LOL!!!
Sorry... naparami pala ako ng reply... akala ko di nagsend kahapon...
paano ba delete yung iba??
Peace!
It looks like solid state batteries are the next big thing. Will manufacturers allow retrofits to...
All New Toyota Corolla Cross
