Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    May 2007
    Good day.. Ask ko lang po kung ano problem ng auto ko. Corrolla GLI po sya 93 model. Nagbabawas po kasi ng langis and pag matagal na sya tumatakbo medyo mausok na lalo pag mag change gear na. Wala naman sya tagas ng langis sa grahe nmin kaya nagta2ka ako kung bakit lagi kulang langis nya. Eh office house lang takbo nya. Almost one hour lang per day tinatakbo nya.. Need some advise para pagpunta ko sa shop im sure na di huhulaan kung ano sira.. thanks..
    May 2007
    1. please check kung may langis sa radiator mo. if there is oil in the water may leak na cylinder head mo kailangan mo ng top overhauling.
    2. if no. 1 is ok pwedeng kumakain na ng langis ang piston and that explains the black smoke. medyo malaki ang problem if this is the case dapat na iparebore yung engine block or kung nagtitipid pa pwede ipadukot yung piston na may leak na.
    Dec 2007
    Quote Originally Posted by mkeculit View Post
    hey bro, mukhang may blowby na makina mo. since na nag babawas ng langis ang makina, pero wala namang tulo. so in this case, you probably have a very worn out Piston Rings and Valve Stem Seals and Guides. which are all internal engine problems.
    anywayz, kung dadalhin mo sa shop yung kotse mo. ipa compression test mo muna ang makina, then post mo dito ang results.
    aite, peace.
    Dec 2007
    Why compression test?? Magbabayad ka lang..
    for overhauling na yan....
    sure
    Dec 2007
    sure ka
    Dec 2007
    sure ka na
    Dec 2007
    sonjeffrey ok na naiitindihan naman namin promise!! Peace bro
    mkeculit,
    Mileage? Malangis ba tambucho? Smell of exhaust?
    May 2007
    Quote Originally Posted by 4JGtootsie View Post
    mkeculit,
    Naku, dalhin mo na agad sa E.R kailangan na nang internal operation yong tsikot mo. Mukhang may sakit na oilgastronome.
    Talagang serious si sonJeffry. peace bro.
    Dec 2007
    LOL!!!
    Sorry... naparami pala ako ng reply... akala ko di nagsend kahapon...
    paano ba delete yung iba??
    Peace!
    Nov 2003
    you're better off having it diagnosed by a shop than here on the board where people cannot see what is wrong with it imo.
    Dec 2020
    Good day mga Sir. I have the same problem. Mausok at malakas magbawas ng langis ang sasakyan ko. Bagong palit pistons and piston rings, bagong palit ang valve seals. Hindi naman nagbago ang performance, malakas pa din ang hatak, hindi nagbabawas ng tubig at walang langis sa radiator, not overheating, problema lang talaga usok at nagbabawas ng langis. Any idea and advise will be very much appreciated. Thanks in advance mga kaTsikot.
    Jul 2013
    Quote Originally Posted by rvchicz View Post
    same car? GLI 93?
    usok - have the injection system checked/calibrated
    langis - gaano kalakas yung bawas, anong oil gamit mo (20-50?) and sure ka ba na walang tagas?
    Dec 2020
    same car? GLI 93?
    No Sir. Mini Van sya. Suzuki f6a engine. 1liter every 300 kms. ang nababawas, 20-40 ang langis. Wala namang tagas na naiiwan sa garahe. Kagagawa lang about 2 months ago.
    if you're losing oil, ma-usok nang maitim ang exhaust, and your garage floor is not oiled up,
    it probably means you're burning oil along with the gas, in the combustion chamber, i.e., the cylinder.
    how the oil got there...
    Jan 2008
    palpak yung gawa dyan 2 mos ago.. meron din ako dati nyan suzuki scrum yung engine na nasa likod parang bus.
    bumigay yung overhead gasket nun, mix ang oil at water kaya napa overhaul ko. after that, no problem na. tumakbo pa sa akin ng more than 100k kms bago ko nabenta
    pa check mo yung compression to verify, baka may singaw na sa cylinder walls / piston
    Jun 2011
    Bale sa mga nasabi kung oil sa cylinders,
    1. Cylinder wall/piston
    2. Head gasket, or warped cylinder head
    3. Valve guide
    4. Spark plus seating (kung oil cooled)
    Puwedeng tigngan,
    1. Usok sa pipe, soot sa tail pipe
    (Ay mausok na nga pala)
    2. Compression test
    3. Check spark plugs kung oil covered
    4. Silipin sa intake or exhaust ports,
    Kung may oil fouling sa valves
    Dec 2020
    Oo nga sir eh. Pagkatapos kasi magawa, hindi na nawala ang usok. Sabi ng mechanic after 1week daw mawawala ang usok kaso eto nga, 2months na mausok pa din. And worst, nagbabawas pa ng langis. Maayos pa naman daw ang walls, walang tama, hindi pa maluwag. Ayaw ding tumanggap ng backjob kaya umabot na ng 2months. Thank you sir for the info and advice.
    Dec 2020
    Quote Originally Posted by bxr monkey View Post
    3. Valve guide
    Puwedeng tigngan,
    2. Compression test
    Thank you sir. I will do that.
    Dec 2020
    Yun nga ang tanong sir, how the oil got there. At saka puti ang usok niya, continious as the engine runs.
Engine Problem
