Results 11 to 20 of 21
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 6th, 2008 12:21 PM #11you're better off having it diagnosed by a shop than here on the board where people cannot see what is wrong with it imo.
- Dec 2020
- 13
January 27th, 2021 11:41 AM #12Good day mga Sir. I have the same problem. Mausok at malakas magbawas ng langis ang sasakyan ko. Bagong palit pistons and piston rings, bagong palit ang valve seals. Hindi naman nagbago ang performance, malakas pa din ang hatak, hindi nagbabawas ng tubig at walang langis sa radiator, not overheating, problema lang talaga usok at nagbabawas ng langis. Any idea and advise will be very much appreciated. Thanks in advance mga kaTsikot.
January 27th, 2021 12:39 PM #13
- Dec 2020
- 13
January 27th, 2021 05:48 PM #14
- 52,731
January 27th, 2021 08:45 PM #15if you're losing oil, ma-usok nang maitim ang exhaust, and your garage floor is not oiled up,
it probably means you're burning oil along with the gas, in the combustion chamber, i.e., the cylinder.
how the oil got there...
- Jan 2008
- 4,726
January 27th, 2021 09:28 PM #16palpak yung gawa dyan 2 mos ago.. meron din ako dati nyan suzuki scrum yung engine na nasa likod parang bus.
bumigay yung overhead gasket nun, mix ang oil at water kaya napa overhaul ko. after that, no problem na. tumakbo pa sa akin ng more than 100k kms bago ko nabenta
pa check mo yung compression to verify, baka may singaw na sa cylinder walls / piston
- Jun 2011
- 1,080
January 27th, 2021 10:14 PM #17Bale sa mga nasabi kung oil sa cylinders,
1. Cylinder wall/piston
2. Head gasket, or warped cylinder head
3. Valve guide
4. Spark plus seating (kung oil cooled)
Puwedeng tigngan,
1. Usok sa pipe, soot sa tail pipe
(Ay mausok na nga pala)
2. Compression test
3. Check spark plugs kung oil covered
4. Silipin sa intake or exhaust ports,
Kung may oil fouling sa valves
- Dec 2020
- 13
January 28th, 2021 10:03 AM #18Oo nga sir eh. Pagkatapos kasi magawa, hindi na nawala ang usok. Sabi ng mechanic after 1week daw mawawala ang usok kaso eto nga, 2months na mausok pa din. And worst, nagbabawas pa ng langis. Maayos pa naman daw ang walls, walang tama, hindi pa maluwag. Ayaw ding tumanggap ng backjob kaya umabot na ng 2months. Thank you sir for the info and advice.
- Dec 2020
- 13
- Dec 2020
- 13
January 28th, 2021 10:13 AM #20
Xiaomi E-Car
