Originally Posted by
jick.cejoco
Sir,based on my experience.nagbara ang oil strainer nyan kya umilaw ang oil warning indicator light.
Kung nagbara ang strainer dahil sa sludge/debris, chemical cleaning lang ang kailangan. I did this operation many times. Drain the oil as much as you can, reinstall the drain plug, through the dipstick tube pour a solution of gasoline and degreaser(kleenol, simple green or any readily available liquid degreaser) and let soak for about four hours. Do not crank the engine. Drain the oil pan of the solution. The gasoline dissolves the softer sludge while the degreaser dissolves the caked on gum and varnish
