Results 11 to 20 of 33
Tsikot Member Rank 3
- Dec 2002
- 636
May 27th, 2003 01:23 AM #11bullet,
Hope this does not come across the wrong way, but are you sure you checked the correct dipstick- the engine oil dipstick and not the one for the auto tranny? I can't imagine draining the oil pan and still get a full reading on the dipstick.8O
May 27th, 2003 01:41 AM #12
overfilling oil is bad for the engine...the excess oil will surely destroy the gasketts under the engine..and it's bad for the crankshaft.
just my .02
May 27th, 2003 06:56 AM #13
Indeed it is harmful to the engine. My cousin over filled his L200 back in '96, without checking the level, he drove his truck, he heard gurgling noises, the engine sputtering then without warning, the truck revved so hard, thick, I mean really thick white smoke bellowed from the exhaust and the worse thing is the engine cannot be turned off! the traffic behind him cannot move on or overtake him because the smoke totally obscured their vision. It took about 3 minutes or so before a concerned motorist approached him and opened the air filter to choke the air intake with a cloth. The engine stopped but the damage has been done, piston rings and all. After the overhaul, he sold the pick-up.
- 267
May 27th, 2003 06:39 PM #14Originally Posted by bullet
After filling the recommended oil capacity in your sump you should start the engine to let some oil fill the newly installed oil filter then check for oil leaks as well. After shutting off the engine wait at least 15mins or better after an overnight parking, before checking the dipstick again. Remember to check the oil level while the car is parked on a level ground.
Overfilling your sump will cause the motor oil to foam and create to much pressure that oil will seek exit and ruin your crankshafts oil seals, gaskets, too much carbon buildup in the combustion chamber and other costly engine damage will result.
Its better to stick in between the maximum and the minimum mark of your dipstick! :D
May 27th, 2003 10:11 PM #16
Kailangan ba na start mo muna yung engine and after that shut off the engine before checking the oil dipstick? I was informed by Isuzu Manila to do that when checking the oil dipstick. Kasi pag hindi pa na start yung dipstick ay over sa maximum limit, but after na ma start at icheck yung oil level ay within the level requirement.
February 2nd, 2012 02:44 AM #17
reviving this thread.. i was about to ask the same question.. heck as a 1st time car owner, i thought it was only a mere observation when last year i had to drain the excess oil from my CRV due to a great loss of torque..
2 weeks back, had a quick oil-change at a Shell station,, and the mechanic just overfilled my crank case,, nalingat lang ako sandali.. nung nagreklamo ako,, he told me "ala naman issue yan",, (he looks quite senior) , so di na ako nagreklamo.. now, here comes the issue again,, im loosing power na naman specially at low gear & during quick launches at traffic lights..
now confirming from this thread that excess oil is a NO NO,, kailan kaya matututo ang mga gasoline station guys na huwag mag-overfill ng oil, without explicitly reminding them? kakainis kasi,, DIY drain excess oil na naman ako..
February 2nd, 2012 07:45 AM #18
overfilling the crankcase results in the engine oil being whipped by the connecting rods and the crankshaft creating foam of the engine oil. foam oil does not lubricate moving parts as well as liquid engine oil. the foam oil gets carried into the intake through the pcv valve and it serves as fuel inside the combustion chambers as mentioned by ibaloi. this unintentional temporary fuel supply can not be controlled and the runaway engine has a potential to self destruct because of uncontrolled engine speed. similar to claims about engines running wild, a novice driver panics and causes an accident causing harm to himself and/or other motorists.
- Dec 2006
- 273
February 2nd, 2012 07:12 PM #19I dont fill my crankcase up to the "F" level of my dipstick. I only fill it up to 3/4. Kapag overfill, sisirain nya ang mga engine gaskets which results to leaks. Also, kapag overfill, pahihirapan mo yung makina na mag-circulate ng oil sa buong makina, which will loose konting power (instead na ginagamit mo na - pag takbo ng sasakyan)..
Para din sa tao kapag high blood pressure, maaring ma-damage mga ugat-ugat natin, di ba?
March 2nd, 2012 03:20 PM #20
I think we can agree to disagree on this. But I'm going to nitpick the point about deionized...
Coolant...
