Results 21 to 27 of 27
- Jul 2010
- 570
July 5th, 2015 07:06 PM #22Don't forget also to test also the continuity of carbon rotor contact of distributor cap...Loose contact will cause weak high voltage transferred to spark plug and also cause overheating of your ignition coil. Resistance should between 0 ohm to 300 ohms. Test point would be the button contact and high voltage post of distributor cap..
July 5th, 2015 07:21 PM #23
Test the spark intensity with a spark tester similar to this:
http://ecx.images-amazon.com/images/...HL._SY355_.jpg
Or this:
http://www.mr2.com/TEXT/DavidKucharczyk/t8k_80.jpg
If it can jump this gap chances are you have enough voltage to run the car efficientlyLast edited by jick.cejoco; July 5th, 2015 at 07:25 PM.
- Aug 2003
- 9,720
August 4th, 2015 10:25 AM #24Just thought i'd give some closure to this thread....
So i finally called in a mechanic last week to check the car. Surprise surprise, it ran without issues. He actually commented na maganda pa nga raw yung takbo :0
Ang sabi ng mekaniko, baka me bara lang daw somewhere sa fuel/carb, and to just let it run idle every day for 30min or so, para matanggal yung bara. He also said not so load up on unleaded fuel, nakakabara daw?
Anyways, i'll observe for a week, then i-test drive ako around the block.
- Sep 2015
- 4
September 21st, 2015 08:36 AM #25
- Oct 2015
- 17
November 14th, 2015 11:49 PM #26help mga master binasa ko na rin lahat ng mga msgs..
pina top overhaul ko po Honda Accord ko . kasi nagbabawas po tubig at umiinit pag long drive na nasa 3/4 temp
Cyclinder Head Gasket > Valve Seal > Change oil > Oil Filter
CLEAN THROTTLE
ok na sya sa temp.
Ang problem ko po ngyon pag pinaandar ko 1st gear then go pupugak pugak po ang tunok nya at kumakadyot kadyot 2ng gear ganun din po 3rd gear hirap na sya humatak need mo talaga tapakan yung accelerator...
then pansin ko po lumakas sa kunsumo..
CLEAN THROTTLE
ok na sya sa temp.
pahabol po mga bossing....yung isang high tension wire ko po my bitak pala sya...my bearing po ba yun kaya sa parang sinisinok or palyado?
- Jun 2008
- 1,741
November 15th, 2015 02:57 AM #27palitan mo high tension cable, clean/change spark plugs. observebkung mag ok.
