Results 1 to 20 of 27
Threaded View
    Jul 2010
    Don't forget also to test also the continuity of carbon rotor contact of distributor cap...Loose contact will cause weak high voltage transferred to spark plug and also cause overheating of your ignition coil. Resistance should between 0 ohm to 300 ohms. Test point would be the button contact and high voltage post of distributor cap..
    Attached Thumbnails Attached Thumbnails testing-distributor-cap-rotor-contact.jpg
Engine dies when idling
