Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    #21
    A colleague of mine prefers the Color of the coolant NOT the same color as rust. As he mentioned, the one in Shell is color orange. Not sure about this.
    His reasoning is how will he know if the radiator has rust already if the coolant is color orange.
    Jan 2009
    #22
    Quote Originally Posted by Macmon View Post
    That's not really true. With the proper coolant, you shouldn't have any rust at all. And besides, if you do have a rust problem, the water will become cloudy/muddy orange (as opposed to clear orange) and would coat every surface it touches with rust. To do a proper inspection, check the radiator cap pressure relief spring/valve or other areas where coolant water has passed through like the reservoir bottle, for tell-tale signs of rust.
    Aug 2004
    #23
    While water has a higher heat capacity than coolant, a low-coolant high-water mix is not necessarily superior... the higher heat capacity is more than offset by the lower boiling point, which lessens the effectiveness of the cooling system. Water is only more effective until it boils... once it's boiling, it loses its ability to cool the engine effectively.
    Jan 2009
    #24
    Pure water == faster rust. I just use Prestone pre-mixed para di hassle. And make sure your radiator fins are always clean to make it efficient in heat transfer.
    #25
    Pure water is better than using coolant. Distilled drinking water is best for your cooling system. Kung gagamit ka ng tap water, ok din, basta masipag ka lang mag-palit ng tubig (flush)..every month.
    #26
    Quote Originally Posted by macgyver1432000 View Post
    You'll still need to use some additives because plain water will just rust the insides of the radiator. Rust will just build up at the bottom and in the small tubes. With enough accumulation, the tubes can get blocked.
    #27
    +1000000000
    experienced that already even if you clean or flush the radiator regularly
    #28
    Tanong ko lang mga bro, may dapat bang gamitin pag mag-flush ng tubig sa radiator para matanggal yung rust, kac yung kotse ko hindi ko alam kung may coolant, nagdadagdag lang ako ng tubig pag medyo may bawas na, kasi nabili ko yung car january of this year, gusto ko nga mag-flush ng radiator para mapalitan ko na ng may coolant mixture, although di pa naman ako nakaranas mag-overheat eh, ayoko pang intaying mangyari yun.
    Thanks!!!
    Jun 2009
    #29
    ok lang pang flush ang tap water as long na di ka nakakaranas na tumataas ang temperature
    do it at least two times for two days para matanggal ng husto ang mga latak at dumi sa loob ng radiator
    basta't malinis na yung lumalabas na tubig sa radiator ready na yan lagyan ng coolant
    Apr 2004
    #30
    if i remember correectly most guys over at BITOG advocate "silicate" free coolants for hondas because apparently hondas have small rubber parts in their cooling systems. silicate in the coolant has a nasty habit of drying out and flaking, and when it flakes, the little particles clog up the system, gel, or destroy the rubber/plastic based parts of the system. years ago i recall wondering why the factory bought coolant for the nissans (white bottle, green fluid) would dry out and leave a hard, flaky residue where i spilled it or at the bottle's mouth. baka ito yun, kako.
    i remember having a hard time looking for a coolant without the said ingredient (check the back lable of the bottle where the list of components is listed). some variants of prestone had it, as did shell (yoko bumili na Honda coolant, parang overkill na kasi eh). the only one who didn't have it was caltex long life, balck bottle, concentrate, red fluid. i put that in. it was also the brand recommended at BITOG, where it's called chevron/texaco or something.
    Aug 2008
    #31
    Quote Originally Posted by sboogie View Post
    +1000000000
    mga sirs tanong ko na lang din. how often do we flush water on our radiator? mine's got a bit of a rust build up kasi. bale ang ginagawa ko ay coolant sa reservoir at distilled water naman sa mismong radiator, pero may rust pa rin. ok lang po ba ito or much bettter if i put coolant mixture na rin sa radiator mismo? TIA!
    #32
    Paghaluin mo na iyong coolant 50/ 50 mixture at distiled water . Kung mag flush ka ng tubig sa radiator siguraduhing mong malinis na and radiator mo bago mo ilagay iyong coolant. Gumamit ka ng water hose ilagay mo sa radiator habang umaandar makina para matangal lahat ang dumi at kalawang sa loob ng radiator..Kung ako tatanungin mo kung gaano kadalasan papalitan tubig sa radiator . Kung tap water gagamitin mo kahit every 4 days para malinis maigi radiator mo .pagalam mo ng malinis at saka lagyan mo ng coolant .
    Aug 2008
    #33
    Quote Originally Posted by speed unlimited View Post
    ok, salamat sir sa tip. will do that.
Engine coolant: Is water enough?
